[fusion-commits] r3007 - sandbox/adsk/3.1n/layers/MapGuide
svn_fusion at osgeo.org
Tue Sep 5 23:03:49 PDT 2017
Author: zhanga
Date: 2017-09-05 23:03:49 -0700 (Tue, 05 Sep 2017)
New Revision: 3007
sandbox/adsk/3.1n/layers/MapGuide/MapGuide.js
Fix issue that Selection Panel is wrong after de-select features.
Modified: sandbox/adsk/3.1n/layers/MapGuide/MapGuide.js
--- sandbox/adsk/3.1n/layers/MapGuide/MapGuide.js 2017-06-26 14:20:43 UTC (rev 3006)
+++ sandbox/adsk/3.1n/layers/MapGuide/MapGuide.js 2017-09-06 06:03:49 UTC (rev 3007)
@@ -1379,6 +1379,7 @@
if (this.previousSelection != null)
+ this.previousAttributes = null;
this.previousSelection.clear();
@@ -1992,6 +1993,9 @@
//Nothing to merge, return original
return attributes;
+ if (!attributes.hasSelection) {
+ return prevAttributes;
//Start off with prevAttributes as the base
var merged = {};
merged.hasSelection = prevAttributes.hasSelection;
@@ -2040,16 +2044,20 @@
if (mergeSelection == true)
sel.merge(this.previousSelection);
- attributes = this.mergeAttributes(attributes, this.previousAttributes);
+ if (sel.nLayers > 0)
+ attributes = this.mergeAttributes(attributes, this.previousAttributes);
var selText = sel.getSelectionXml();
- this.previousSelection = sel;
//Because the QUERYMAPFEATURES 2.6.0 response contains mostly everything we need, we cut down
//on lots of async request ping-pong. So we can just update the selection image and notify any
//interested parties of the new selection attributes
if (selText != "" && selText != null) {
+ this.previousSelection = sel;
this.previousAttributes = attributes;
- this.updateMapSelection(selText, false, mergeSelection);
+ if (sel.isDeselect)
+ this.updateMapSelection(selText, false, false, true);
+ else
+ this.updateMapSelection(selText, false, mergeSelection);
} else {
//Only clear if we're not merging an empty selection
if (mergeSelection == false) {
@@ -2088,6 +2096,7 @@
Fusion.SimpleSelectionObject = OpenLayers.Class({
aLayers : null,
nLayers : 0,
+ isDeselect: false,
initialize: function(featureInfoResponse)
@@ -2185,6 +2194,7 @@
if (previousSelection != null && previousSelection.nLayers > 0)
+ this.isDeselect = false;
for (var prevSelIndex = 0; prevSelIndex < previousSelection.nLayers; prevSelIndex++)
var prevSelLayer = previousSelection.aLayers[prevSelIndex];
@@ -2205,11 +2215,12 @@
// the feature was previously selected, so toggle it off when selected again
currentLayer.removeFeatures(prevSelFeatureIndexes);
+ this.isDeselect = true;
if (currentLayer.featIds.length == 0)
- this.clear();
+ this.removeLayer(currentLayer);
else
@@ -2228,6 +2239,30 @@
+ getLayerIndex : function(layer)
+ var index = -1;
+ for (var i=0; i<this.nLayers; i++)
+ if (this.aLayers[i] == layer)
+ index = i;
+ break;
+ return index;
+ removeLayer: function(layer)
+ var index = this.getLayerIndex(layer);
+ if (index >=0 && index < this.nLayers)
+ this.aLayers.remove(index);
+ this.nLayers--;
clear: function()
this.aLayers = [];
More information about the fusion-commits
