[fusion-commits] r3037 - sandbox/cms_refactor/lib
svn_fusion at osgeo.org
Thu Jul 26 07:24:56 PDT 2018
Author: jng
Date: 2018-07-26 07:24:56 -0700 (Thu, 26 Jul 2018)
New Revision: 3037
sandbox/cms_refactor/lib/fusion.js
Re-order the init so that we don't try to fetch the appdef if we already had it loaded.
Modified: sandbox/cms_refactor/lib/fusion.js
--- sandbox/cms_refactor/lib/fusion.js 2018-07-26 13:56:43 UTC (rev 3036)
+++ sandbox/cms_refactor/lib/fusion.js 2018-07-26 14:24:56 UTC (rev 3037)
@@ -384,17 +384,90 @@
this.sRedirectScript = 'redirect.php';
configUrl += '&method=get';
- if (Fusion.configuration) {
- //config.json loaded via single file build
- this.serverSet();
+ var onAppDefFetched = OpenLayers.Function.bind(function() {
+ if (Fusion.configuration) {
+ //config.json loaded via single file build
+ this.serverSet();
+ } else {
+ var options = {
+ onSuccess: OpenLayers.Function.bind(this.getConfigCB, this),
+ onFailure: OpenLayers.Function.bind(this.serverFailed, this),
+ method: 'get'
+ this.ajaxRequest(configUrl, options);
+ }, this);
+ var mapAgentUrl = getAgentUrl();
+ var bAlreadyInit = (this.newTemplatePath === true && this.appDefJson != null);
+ var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
+ if (!bAlreadyInit &&
+ appDefUrl && (
+ appDefUrl.indexOf('Library') == 0 ||
+ appDefUrl.indexOf('Session') == 0)) {
+ var fetchAppDef = function(appDefUrl, sessionId) {
+ var xhr = getXmlHttpRequest();
+ xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ sessionId, false);
+ try {
+ xhr.send(null);
+ var appDefXML = xhr.responseXML.documentElement;
+ if (appDefXML) {
+ var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
+ var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
+ var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
+ var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
+ var stamenElement = appDefXML.getElementsByTagName("StamenScript")[0];
+ addElement(googleElement);
+ addElement(yahooElement);
+ addElement(veElement);
+ addElement(osmElement);
+ addElement(stamenElement);
+ var bingMapKeyElement = appDefXML.getElementsByTagName("BingMapKey")[0];
+ if (bingMapKeyElement) {
+ var bingMapKey = bingMapKeyElement.textContent;
+ if (!bingMapKey)
+ bingMapKey = bingMapKeyElement.text;
+ Fusion.bingMapKey = bingMapKey;
+ onAppDefFetched();
+ } catch (e) {
+ if (xhr.statusText == "MgResourceNotFoundException") {
+ alert("Failed to fetch Application Definition. The specified resource could not be found");
+ } //Anything else we can't do anything about as TraceKit is probably not loaded yet
+ var getSiteVersion = function(sessionId) {
+ xhr.open("GET", mapAgentUrl + "?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&SESSION="+ sessionId, false);
+ xhr.send(null);
+ var verXML = xhr.responseXML.documentElement;
+ var el = verXML.getElementsByTagName("Version")[0];
+ var version = el.textContent || el.text;
+ var bits = version.split('.');
+ return new Array(parseInt(bits[0]),
+ parseInt(bits[1]),
+ parseInt(bits[2]),
+ parseInt(bits[3]));
+ var passedSessionId = Fusion.getQueryParam('Session');
+ if (passedSessionId == null || passedSessionId == "" ){
+ createSessionId(Fusion.getQueryParam("Username"), Fusion.getQueryParam("Password"));
+ } else {
+ Fusion.sessionId = passedSessionId;
+ Fusion.siteVersion = getSiteVersion(passedSessionId);
+ fetchAppDef(appDefUrl, Fusion.sessionId);
} else {
- var options = {
- onSuccess: OpenLayers.Function.bind(this.getConfigCB, this),
- onFailure: OpenLayers.Function.bind(this.serverFailed, this),
- method: 'get'
- this.ajaxRequest(configUrl, options);
@@ -647,8 +720,8 @@
* r - {XMLHttpRequest} an XMLHttpRequest object
getConfigCB: function(r) {
- if (r.responseText) {
- eval("this.configuration="+r.responseText);
+ if (r.responseText) {
+ this.configuration = Fusion.parseJSON(r.responseText);
this.serverSet();
} else {
//console.log('Error parsing configuration file, it is not valid somehow?');
@@ -1602,7 +1675,8 @@
xhr.open("GET", fusionURL, false);
xhr.send(null);
+ //Can't use parseJSON as this JSON file will most likely have comments
eval("Fusion.configuration=" + xhr.responseText);
var s = Fusion.configuration.mapguide.webTierUrl;
/* if it is set, use it ... otherwise assume fusion is installed in
@@ -1683,71 +1757,4 @@
xhr.send(params);
- var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
- if (appDefUrl && (
- appDefUrl.indexOf('Library') == 0 ||
- appDefUrl.indexOf('Session') == 0)) {
- var fetchAppDef = function(appDefUrl, sessionId) {
- var xhr = getXmlHttpRequest();
- var mapAgentUrl = getAgentUrl();
- xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ sessionId, false);
- try {
- xhr.send(null);
- var appDefXML = xhr.responseXML.documentElement;
- if (appDefXML) {
- var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
- var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
- var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
- var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
- var stamenElement = appDefXML.getElementsByTagName("StamenScript")[0];
- addElement(googleElement);
- addElement(yahooElement);
- addElement(veElement);
- addElement(osmElement);
- addElement(stamenElement);
- var bingMapKeyElement = appDefXML.getElementsByTagName("BingMapKey")[0];
- if (bingMapKeyElement) {
- var bingMapKey = bingMapKeyElement.textContent;
- if (!bingMapKey)
- bingMapKey = bingMapKeyElement.text;
- Fusion.bingMapKey = bingMapKey;
- } catch (e) {
- if (xhr.statusText == "MgResourceNotFoundException") {
- alert("Failed to fetch Application Definition. The specified resource could not be found");
- } //Anything else we can't do anything about as TraceKit is probably not loaded yet
- var getSiteVersion = function(sessionId) {
- xhr.open("GET", mapAgentUrl + "?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&SESSION="+ sessionId, false);
- xhr.send(null);
- var verXML = xhr.responseXML.documentElement;
- var el = verXML.getElementsByTagName("Version")[0];
- var version = el.textContent || el.text;
- var bits = version.split('.');
- return new Array(parseInt(bits[0]),
- parseInt(bits[1]),
- parseInt(bits[2]),
- parseInt(bits[3]));
- var passedSessionId = Fusion.getQueryParam('Session');
- if (passedSessionId == null || passedSessionId == "" ){
- createSessionId(Fusion.getQueryParam("Username"), Fusion.getQueryParam("Password"));
- } else {
- Fusion.sessionId = passedSessionId;
- Fusion.siteVersion = getSiteVersion(passedSessionId);
- fetchAppDef(appDefUrl, Fusion.sessionId);
More information about the fusion-commits
