[fusion-commits] r3017 - in trunk: . layers/MapGuide
svn_fusion at osgeo.org
Thu Mar 8 05:07:19 PST 2018
Author: jng
Date: 2018-03-08 05:07:19 -0800 (Thu, 08 Mar 2018)
New Revision: 3017
trunk/
trunk/layers/MapGuide/MapGuide.js
Merged revision(s) 3007 from sandbox/adsk/3.1n:
Fix issue that Selection Panel is wrong after de-select features.
Index: trunk
--- trunk 2018-03-08 13:05:33 UTC (rev 3016)
+++ trunk 2018-03-08 13:07:19 UTC (rev 3017)
Property changes on: trunk
___________________________________________________________________
Modified: svn:mergeinfo
## -1,7 +1,7 ##
/branches/fusion-mg24:2560
/branches/fusion-mg26:2855,2869
/sandbox/adsk/2.6l:2911
-/sandbox/adsk/3.1n:2925-2927,2935
+/sandbox/adsk/3.1n:2925-2927,2935,3007
/sandbox/adsk/3.2o:2969-2972,2974,2978-2984
/sandbox/createruntimemap:2699-2708
/sandbox/jxlib-3.0:1957-2248
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2018-03-08 13:05:33 UTC (rev 3016)
+++ trunk/layers/MapGuide/MapGuide.js 2018-03-08 13:07:19 UTC (rev 3017)
@@ -1556,6 +1556,7 @@
if (this.previousSelection != null)
+ this.previousAttributes = null;
this.previousSelection.clear();
@@ -2264,6 +2265,9 @@
//Nothing to merge, return original
return attributes;
+ if (!attributes.hasSelection) {
+ return prevAttributes;
//Start off with prevAttributes as the base
var merged = {};
merged.hasSelection = prevAttributes.hasSelection;
@@ -2312,16 +2316,20 @@
if (mergeSelection == true)
sel.merge(this.previousSelection);
- attributes = this.mergeAttributes(attributes, this.previousAttributes);
+ if (sel.nLayers > 0)
+ attributes = this.mergeAttributes(attributes, this.previousAttributes);
var selText = sel.getSelectionXml();
- this.previousSelection = sel;
//Because the QUERYMAPFEATURES 2.6.0 response contains mostly everything we need, we cut down
//on lots of async request ping-pong. So we can just update the selection image and notify any
//interested parties of the new selection attributes
if (selText != "" && selText != null) {
+ this.previousSelection = sel;
this.previousAttributes = attributes;
- this.updateMapSelection(selText, false, mergeSelection);
+ if (sel.isDeselect)
+ this.updateMapSelection(selText, false, false, true);
+ else
+ this.updateMapSelection(selText, false, mergeSelection);
} else {
//Only clear if we're not merging an empty selection
if (mergeSelection == false) {
@@ -2360,6 +2368,7 @@
Fusion.SimpleSelectionObject = OpenLayers.Class({
aLayers : null,
nLayers : 0,
+ isDeselect: false,
initialize: function(featureInfoResponse, bClean)
@@ -2481,6 +2490,7 @@
if (previousSelection != null && previousSelection.nLayers > 0)
+ this.isDeselect = false;
for (var prevSelIndex = 0; prevSelIndex < previousSelection.nLayers; prevSelIndex++)
var prevSelLayer = previousSelection.aLayers[prevSelIndex];
@@ -2501,11 +2511,12 @@
// the feature was previously selected, so toggle it off when selected again
currentLayer.removeFeatures(prevSelFeatureIndexes);
+ this.isDeselect = true;
if (currentLayer.featIds.length == 0)
- this.clear();
+ this.removeLayer(currentLayer);
else
@@ -2524,6 +2535,30 @@
+ getLayerIndex : function(layer)
+ var index = -1;
+ for (var i=0; i<this.nLayers; i++)
+ if (this.aLayers[i] == layer)
+ index = i;
+ break;
+ return index;
+ removeLayer: function(layer)
+ var index = this.getLayerIndex(layer);
+ if (index >=0 && index < this.nLayers)
+ this.aLayers.remove(index);
+ this.nLayers--;
clear: function()
this.aLayers = [];
More information about the fusion-commits
