[fusion-commits] r3026 - in branches/fusion-mg31: . layers/MapGuide lib lib/jxLib widgets widgets/Measure
svn_fusion at osgeo.org
Thu Mar 8 05:23:02 PST 2018
Author: jng
Date: 2018-03-08 05:23:01 -0800 (Thu, 08 Mar 2018)
New Revision: 3026
branches/fusion-mg31/
branches/fusion-mg31/layers/MapGuide/MapGuide.js
branches/fusion-mg31/lib/Map.js
branches/fusion-mg31/lib/jxLib/jxlib.uncompressed.js
branches/fusion-mg31/widgets/Legend.js
branches/fusion-mg31/widgets/MapMenu.js
branches/fusion-mg31/widgets/Maptip.js
branches/fusion-mg31/widgets/Measure.js
branches/fusion-mg31/widgets/Measure/Measure.php
Merged revision(s) 3008-3012 from sandbox/adsk/3.1n:
This submission solved 3 issues:
1. Hide group in legend tree if it is empty.
2. Set map initial active state in "Maps" menu.
3. If there are more than one base layer groups and one of them is invisible initially, the features of the layer in the group cannot be selected after show the group. It is because we don't save the map object when clicking the check box of base layer group. I added a call of GETVISIBLEMAPEXTENT to workaround this issue.
This submission made 3 changes:
1. Suppress Fusion error in client when query features/get map tip
2. Turn off map tip by default
3. Fix a typo
Fix bug: Features are selected when using measure tool.
Fix 2 measure issues.
1. fusion error if zoom after click 'Measure' button. It is because the line string is not valid yet. Now add a check for the vertex count before update marker.
2. If there are 2 'Measure' defined (one for distance, the other for area), when switch between the 2 buttons, the 'Unload' of previous page is always after the new page's 'activate', which results in values of some global variables e.g. isDigitizing are not correct. Now we change the event to 'onbeforeunload' to solve the issue.
Index: branches/fusion-mg31
--- branches/fusion-mg31 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31 2018-03-08 13:23:01 UTC (rev 3026)
Property changes on: branches/fusion-mg31
___________________________________________________________________
Modified: svn:mergeinfo
## -1,7 +1,7 ##
/branches/fusion-mg24:2560
/branches/fusion-mg26:2855,2869
/sandbox/adsk/2.6l:2911
-/sandbox/adsk/3.1n:2925-2927,2935,2987,2989,3007
+/sandbox/adsk/3.1n:2925-2927,2935,2987,2989,3007-3012
/sandbox/adsk/3.2o:2969-2972,2974,2978-2984
/sandbox/createruntimemap:2699-2708
/sandbox/jxlib-3.0:1957-2248
Modified: branches/fusion-mg31/layers/MapGuide/MapGuide.js
--- branches/fusion-mg31/layers/MapGuide/MapGuide.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/layers/MapGuide/MapGuide.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -1632,6 +1632,11 @@
this.oLayersOLTile[i].setVisibility(true);
+ this.aShowGroups.push(group.uniqueId);
+ if (this.drawDelay > 0) {
+ this.aHideGroups.erase(group.uniqueId);
+ this.mapExtentsChanged();
} else {
//A group cannot be both hidden and shown, which can be the case if there is a draw
@@ -1656,6 +1661,11 @@
this.oLayersOLTile[i].setVisibility(false);
+ this.aHideGroups.push(group.uniqueId);
+ this.aShowGroups.erase(group.uniqueId);
} else {
@@ -1728,7 +1738,10 @@
if (!this.singleTile) {
var center = this.mapWidget.oMapOL.getCenter();
var display = this.mapWidget.oMapOL.getSize();
+ var showGroups = this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null;
+ var hideGroups = this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null;
+ this.aShowGroups = [];
+ this.aHideGroups = [];
var r = new Fusion.Lib.MGRequest.MGGetVisibleMapExtent(this.getSessionID(),
this._sMapname,
center.lon, center.lat,
@@ -1735,7 +1748,11 @@
this.mapWidget.oMapOL.getScale(),
null,
this._nDpi,
- display.w, display.h);
+ display.w, display.h,
+ null,
+ null,
+ showGroups,
+ hideGroups);
Fusion.oBroker.dispatchRequest(r);
@@ -1843,8 +1860,14 @@
parseMapTip: function(xhr) {
- var o;
- var tooltip = Fusion.parseJSON(xhr.responseText);
+ var tooltip;
+ // Don't show error window, just return if the response is invalid.
+ try {
+ tooltip = Fusion.parseJSON(xhr.responseText);
+ catch (err) {
+ return;
this.oMaptip = {t:"",h:""};
var t = tooltip['FeatureInformation']['Tooltip'];
if (t) {
@@ -2071,7 +2094,15 @@
processSelectedExtendedFeatureInfo: function(r, mergeSelection) {
- var o = Fusion.parseJSON(r.responseText);
+ var o;
+ try {
+ o = Fusion.parseJSON(r.responseText);
+ catch (err) {
+ this.mapWidget._removeWorker();
+ return;
var sel = new Fusion.SimpleSelectionObject(o);
var attributes = this.convertExtendedFeatureInfo(o);
if (mergeSelection == true)
@@ -2110,7 +2141,15 @@
processSelectedFeatureInfo: function (r, mergeSelection) {
+ var o;
+ try {
+ catch (err) {
+ return;
var newSelection = new Fusion.SimpleSelectionObject(o);
if(mergeSelection == true)
Modified: branches/fusion-mg31/lib/Map.js
--- branches/fusion-mg31/lib/Map.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/lib/Map.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -415,6 +415,14 @@
var startIndex = loadOverlays?1:0;
for (var i = this.aMaps.length-1; i >= startIndex; i--) {
if (this.aMaps[i].oLayerOL) {
+ if (this.aMaps[i].oLayerOL2) {
+ this.aMaps[i].oLayerOL2.destroy();
+ if (this.aMaps[i].oLayersOLTile) {
+ for (var j = 0; j < this.aMaps[i].oLayersOLTile.length; j++) {
+ this.aMaps[i].oLayersOLTile[j].destroy();
this.aMaps[i].oLayerOL.destroy();
this.aMaps.splice(i,1);
@@ -422,6 +430,9 @@
this._fMetersperunit = -1;
this.oMapOL.center = null;
+ this.oMapOL.minPx = null;
+ this.oMapOL.maxPx = null;
+ this.oMapOL.zoom = null;
this.maxExtent = new OpenLayers.Bounds();
var storedBase;
if (loadOverlays) {
Modified: branches/fusion-mg31/lib/jxLib/jxlib.uncompressed.js
--- branches/fusion-mg31/lib/jxLib/jxlib.uncompressed.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/lib/jxLib/jxlib.uncompressed.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -16972,7 +16972,7 @@
scroll,
size,
left,
- rigbht,
+ right,
top,
bottom,
n,
Modified: branches/fusion-mg31/widgets/Legend.js
--- branches/fusion-mg31/widgets/Legend.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/widgets/Legend.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -249,7 +249,13 @@
bIncludeVisToggle: true,
offsetsCalculated: false,
+ * Property: bHideEmptyGroups
+ * {Boolean} Determine if a group which has non-visible layer must be draw in the legend.
+ bHideEmptyGroups: true,
initialize: function(legend, widgetTag) {
Fusion.Widget.Legend.LegendRenderer.prototype.initialize.apply(this, [legend]);
@@ -287,7 +293,8 @@
this.showRootFolder = (json.ShowRootFolder && json.ShowRootFolder[0] == 'true') ? true:false;
//do show the map folder by default
this.showMapFolder = (json.ShowMapFolder && json.ShowMapFolder[0] == 'false') ? false:true;
+ this.bHideEmptyGroups = true;
if (!this.showRootFolder) {
//console.log('supressing root folder');
this.oRoot = this.oTree;
@@ -543,9 +550,27 @@
for (var i=map.layerRoot.layers.length-1; i>=0; i--) {
this.updateLayer(map.layerRoot.layers[i], currentScale);
+ if (this.bHideEmptyGroups) {
+ for (var i=0; i<map.layerRoot.groups.length; i++) {
+ this.hideEmptyGroup(map.layerRoot.groups[i]);
this.oTree.thaw();
+ hideEmptyGroup: function(group) {
+ if (group.hasVisibleLayers) {
+ if (group.legend.treeItem) {
+ group.legend.treeItem.domObj.style.display = 'block';
+ for (var i=0; i<group.groups.length; i++) {
+ this.hideEmptyGroup(group.groups[i])
+ } else {
+ group.legend.treeItem.domObj.style.display = 'none';
* remove the dom objects representing the legend layers and groups
@@ -576,6 +601,7 @@
addLayerStyleTreeItems: function(treeItem, items) {
treeItem.tree.freeze();
treeItem.add(items);
@@ -601,7 +627,9 @@
//above are still valid.
treeItem.add(layerTreeItem, 0);
updateGroupLayers: function(group, fScale) {
+ group.hasVisibleLayers = false;
this.updateGroupLayers(group.groups[i], fScale);
@@ -609,10 +637,30 @@
for (var i=group.layers.length-1 ; i >= 0; i--) {
this.updateLayer(group.layers[i], fScale);
+ // Hide empty groups if necessary.
+ if (!this.bHideEmptyGroups)
+ return;
+ // Check if the group has visible layers
+ for (var i=0; i<group.layers.length; i++) {
+ if (group.layers[i].visibleInGroupLegend) {
+ group.hasVisibleLayers = true;
+ break;
+ return;
+ if (group.groups[i].hasVisibleLayers) {
+ break;
updateLayer: function(layer, fScale) {
/* no need to do anything if we are hiding the layer */
if (!layer.displayInLegend || !layer.legend) {
+ layer.visibleInGroupLegend = false;
return;
/* check the layer's current scale range against the previous one
@@ -721,9 +769,12 @@
if (layer.legend.treeItem) {
+ layer.visibleInGroupLegend = true;
layer.legend.treeItem.options.data = layer;
if (!layer.isBaseMapLayer) //Tiled layers don't have a checkbox so there's nothing to check
layer.legend.treeItem.check(layer.visible);
+ } else {
getThemeExpandContextMenu: function(node) {
Modified: branches/fusion-mg31/widgets/MapMenu.js
--- branches/fusion-mg31/widgets/MapMenu.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/widgets/MapMenu.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -80,6 +80,7 @@
var mapGroups = Fusion.applicationDefinition.mapGroups;
this.mapGroupData = {};
+ var oMap = this.getMap();
var buttonSet = new Jx.ButtonSet();
for (var key in mapGroups) {
if (mapGroups[key].mapId) {
@@ -95,6 +96,8 @@
buttonSet.add(menuItem);
this.uiObj.add(menuItem);
+ if (oMap && oMap.mapGroup.mapId == mapGroup.mapId)
+ menuItem.setActive(true);
Modified: branches/fusion-mg31/widgets/Maptip.js
--- branches/fusion-mg31/widgets/Maptip.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/widgets/Maptip.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -180,11 +180,10 @@
if (this.widgetTag.tooltip) {
this.mapTipBtn.setTooltip(this.widgetTag.tooltip);
- if (uiObj.options.active) {
- this.mapTipBtn.setActive(true);
+ // turn off map tip by default
+ this.mapTipBtn.setActive(false);
- this.uiObj = uiObj;
+ this.uiObj = uiObj;
activate : function() {
Modified: branches/fusion-mg31/widgets/Measure/Measure.php
--- branches/fusion-mg31/widgets/Measure/Measure.php 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/widgets/Measure/Measure.php 2018-03-08 13:23:01 UTC (rev 3026)
@@ -83,11 +83,13 @@
function OnUnload() {
- _widget.deactivate();
+ if (_widget)
+ _widget.deactivate();
function SetWidget(widget) {
_widget = widget;
+ _widget.getMap().isDigitizing = true;
_widget.setButtons(document.getElementById("measureStopBtn"), document.getElementById("measureStartBtn"));
@@ -101,7 +103,7 @@
</script>
</head>
-<body id="MeasurementWidgetResults" onload="OnLoad()" onunload="OnUnload()">
+<body id="MeasurementWidgetResults" onload="OnLoad()" onbeforeunload="OnUnload()">
<h1><?php echo $title ?></h1>
<hr />
<p><?php echo $hint ?></p>
Modified: branches/fusion-mg31/widgets/Measure.js
--- branches/fusion-mg31/widgets/Measure.js 2018-03-08 13:22:15 UTC (rev 3025)
+++ branches/fusion-mg31/widgets/Measure.js 2018-03-08 13:23:01 UTC (rev 3026)
@@ -357,6 +357,8 @@
var at = null;
var pixQuantity = 0;
if (geom.CLASS_NAME.indexOf('LineString') != -1) {
+ if(v.length < 2)
+ return;
from = this.getMap().geoToPix(v[0].x,v[0].y);
to = this.getMap().geoToPix(v[1].x,v[1].y);
at = {x: (from.x + to.x) / 2, y: (from.y + to.y) / 2};
@@ -467,6 +469,7 @@
this.getMap().supressContextMenu(true);
this.updateButtonStates();
//This is digitization, so trigger the necessary event
+ this.getMap().isDigitizing = true;
this.getMap().triggerEvent(Fusion.Event.MAP_DIGITIZER_ACTIVATED);
@@ -478,6 +481,7 @@
this.getMap().supressContextMenu(false);
+ this.getMap().isDigitizing = false;
this.getMap().triggerEvent(Fusion.Event.MAP_DIGITIZER_DEACTIVATED);
More information about the fusion-commits
