[fusion-commits] r3029 - in branches/fusion-mg31: . widgets/Search
svn_fusion at osgeo.org
Thu Mar 8 06:30:34 PST 2018
Author: jng
Date: 2018-03-08 06:30:34 -0800 (Thu, 08 Mar 2018)
New Revision: 3029
branches/fusion-mg31/
branches/fusion-mg31/widgets/Search/Search.php
Merged revision(s) 3028 from trunk:
Speculative fix for: https://trac.osgeo.org/mapguide/ticket/2770
Just because we set $bHasPoint = true, don't blindly assume that the geometry we read out is also going to be a point. Render out the default non-point result row if the geometry is not a point.
Index: branches/fusion-mg31
--- branches/fusion-mg31 2018-03-08 14:29:30 UTC (rev 3028)
+++ branches/fusion-mg31 2018-03-08 14:30:34 UTC (rev 3029)
Property changes on: branches/fusion-mg31
___________________________________________________________________
Modified: svn:mergeinfo
## -9,4 +9,4 ##
/sandbox/robust_error_handling:2818-2825
/sandbox/stamen:2873-2875
/sandbox/tiling:2845-2846
-/trunk:2946,2950,2954,2956,2960,2964,2993-2995,2999,3003
\ No newline at end of property
+/trunk:2946,2950,2954,2956,2960,2964,2993-2995,2999,3003,3028
Modified: branches/fusion-mg31/widgets/Search/Search.php
--- branches/fusion-mg31/widgets/Search/Search.php 2018-03-08 14:29:30 UTC (rev 3028)
+++ branches/fusion-mg31/widgets/Search/Search.php 2018-03-08 14:30:34 UTC (rev 3029)
@@ -278,8 +278,10 @@
$coord = $geom->GetCoordinate();
$x = $coord->GetX();
$y = $coord->GetY();
+ echo sprintf("<td class=\"%s\" id=\"%d:%d\" onmousemove=\"SelectRow(%d)\" onclick=\"PointCellClicked('%s', %g, %g, %g)\"> %s</td>\n", !($row%2)? "Search" : "Search2", $row, $i, $row, $selText, $x, $y, $pointZoom, $val);
+ } else {
+ echo sprintf("<td class=\"%s\" id=\"%d:%d\" onmousemove=\"SelectRow(%d)\" onclick=\"CellClicked('%s')\"> %s</td>\n", !($row%2)? "Search" : "Search2", $row, $i, $row, $selText, $val);
- echo sprintf("<td class=\"%s\" id=\"%d:%d\" onmousemove=\"SelectRow(%d)\" onclick=\"PointCellClicked('%s', %g, %g, %g)\"> %s</td>\n", !($row%2)? "Search" : "Search2", $row, $i, $row, $selText, $x, $y, $pointZoom, $val);
} catch (MgException $ex) {
More information about the fusion-commits
