[fusion-commits] r3055 - in sandbox/php8/widgets: QuickPlot Redline/classes
svn_fusion at osgeo.org
Tue May 31 07:47:07 PDT 2022
Author: jng
Date: 2022-05-31 07:47:07 -0700 (Tue, 31 May 2022)
New Revision: 3055
sandbox/php8/widgets/QuickPlot/GeneratePicture.php
sandbox/php8/widgets/Redline/classes/markupmanager.php
Fix up Redline and QuickPlot for PHP8
Modified: sandbox/php8/widgets/QuickPlot/GeneratePicture.php
--- sandbox/php8/widgets/QuickPlot/GeneratePicture.php 2022-05-31 14:46:24 UTC (rev 3054)
+++ sandbox/php8/widgets/QuickPlot/GeneratePicture.php 2022-05-31 14:47:07 UTC (rev 3055)
@@ -60,7 +60,7 @@
$array = explode(",", $args["print_size"]);
$printSize = new Size(ParseLocaleDouble($array[0]), ParseLocaleDouble($array[1]));
- $printSize_pixel = new Size($printSize->width / 25.4 * $printDpi, $printSize->height / 25.4 * $printDpi);
+ $printSize_pixel = new Size(intval($printSize->width / 25.4 * $printDpi), intval($printSize->height / 25.4 * $printDpi));
$array = explode(",", $args["box"]);
$captureBox = CreatePolygon($array);
@@ -115,12 +115,12 @@
$colorString = substr($colorString, 2, 6) . substr($colorString, 0, 2);
$color = new MgColor($colorString);
- $mgReader = $renderingService->RenderMap($map,
- $selection,
+ $mgReader = $renderingService->RenderMap($map,
+ $selection,
$center,
- $scaleDenominator,
- $toSize->width,
- $toSize->height,
+ doubleval($scaleDenominator),
+ intval($toSize->width),
+ intval($toSize->height),
$color,
"PNG",
false);
@@ -137,7 +137,7 @@
imagedestroy($image);
// Crop the normalized image
$croppedImg = imagecreatetruecolor($size->width, $size->height);
- imagecopy($croppedImg, $normalizedImg, 0, 0, (imagesx($normalizedImg) - $size->width) / 2, (imagesy($normalizedImg) - $size->height) / 2, $size->width, $size->height);
+ imagecopy($croppedImg, $normalizedImg, 0, 0, intval((imagesx($normalizedImg) - $size->width) / 2), intval((imagesy($normalizedImg) - $size->height) / 2), $size->width, $size->height);
// Free the normalized image
imagedestroy($normalizedImg);
if ($drawNorthArrow) {
@@ -147,7 +147,7 @@
header ("Content-type: image/png");
imagepng($croppedImg);
- //Uncomment to see what PHP-isms get spewed out that may be tripping up rendering
+ //Uncomment below (and comment the 2 lines above) to see what PHP-isms get spewed out that may be tripping up rendering
//Also replace instances of "////print_r" with "//print_r" to insta-uncomment all debugging calls
ob_start();
@@ -196,10 +196,10 @@
$naRes = 300;
$naMargin = 12;
// Calculate the margin as pixels according to the resolutions
- $margin = $resolution * $naMargin / 25.4;
+ $margin = intval($resolution * $naMargin / 25.4);
// Get the width of the north arrow on the map picture
- $drawWidth = $naWidth * $resolution / $naRes;
- $drawHeight = $naHeight * $resolution / $naRes;
+ $drawWidth = intval($naWidth * $resolution / $naRes);
+ $drawHeight = intval($naHeight * $resolution / $naRes);
// Draw the north arrow on the map picture
imagecopyresized($map, $rotatedNa, $mapWidth - $drawWidth - $margin, $mapHeight - $drawHeight - $margin, 0, 0, $drawWidth, $drawHeight, $naWidth, $naHeight);
// Free the north arrow image
Modified: sandbox/php8/widgets/Redline/classes/markupmanager.php
--- sandbox/php8/widgets/Redline/classes/markupmanager.php 2022-05-31 14:46:24 UTC (rev 3054)
+++ sandbox/php8/widgets/Redline/classes/markupmanager.php 2022-05-31 14:47:07 UTC (rev 3055)
@@ -560,7 +560,7 @@
$basic = (strcmp($this->args["REDLINESTYLIZATION"], "BASIC") == 0);
// Create the Markup Layer Definition. Create or update, this code is the same.
- $hexFgTransparency = sprintf("%02x", 255 * (100 - $this->args['FILLTRANSPARENCY']) / 100); // Convert % to an alpha value
+ $hexFgTransparency = sprintf("%02x", 255 * (100 - intval($this->args['FILLTRANSPARENCY'])) / 100); // Convert % to an alpha value
$hexBgTransparency = $this->args['FILLBACKTRANS'] ? "FF" : "00"; // All or nothing
$bold = array_key_exists('LABELBOLD', $this->args) ? "true" : "false";
$italic = array_key_exists('LABELITALIC', $this->args) ? "true" : "false";
@@ -905,7 +905,7 @@
//Call the service API
- $br = $kmlService->GetFeaturesKml($markupLayer, $bbox, $devW, $devH, $mapDpi, 0, ($kmz ? "KMZ" : "KML"));
+ $br = $kmlService->GetFeaturesKml($markupLayer, $bbox, $devW, $devH, doubleval($mapDpi), 0, ($kmz ? "KMZ" : "KML"));
$len = $br->GetLength();
$outputBuffer = '';
More information about the fusion-commits
