[fusion-commits] r3064 - trunk/layers/MapGuide
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Feb 24 01:45:08 PST 2025
Author: jng
Date: 2025-02-24 01:45:05 -0800 (Mon, 24 Feb 2025)
New Revision: 3064
   trunk/layers/MapGuide/MapGuide.js
Fix clean JSON check. MG 3.3 no longer exists as it has been "upgraded" to 4.0
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2023-04-10 14:38:32 UTC (rev 3063)
+++ trunk/layers/MapGuide/MapGuide.js	2025-02-24 09:45:05 UTC (rev 3064)
@@ -203,10 +203,8 @@
         if (vMajor > 2) { // 3.0 or higher
             this.bUseNativeServices = true;
             this.bHasTileSetSupport = true;
-            if (vMajor == 3) { // 3.x
-                if (vMinor >= 3) { // >= 3.3
-                    this.bHasCleanJsonSupport = true;
+            if (vMajor == 4) { // 4.x
+                this.bHasCleanJsonSupport = true;
         } else {
             if (vMajor == 2) { // 2.x
@@ -324,7 +322,7 @@
                 r.setParams({ version: "3.0.0" });
             if (this.bHasCleanJsonSupport) { //Clean json means no de-arrayification of responses required
-                r.setParams({ version: "3.3.0", clean: 1 });
+                r.setParams({ version: "4.0.0", clean: 1 });
             var mapName = this.calcMapName(resourceId, true);
             r.setParams({
@@ -1473,7 +1471,7 @@
        this.selectionColor,
        this.selectionImageFormat);
             var callback = OpenLayers.Function.bind(this.onNativeSelectionUpdate, this, zoomTo, returnAttributes);
             // use 'post' because selText could be a long string.
@@ -1754,7 +1752,7 @@
             var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeExtendedFeatureInfo, this) : OpenLayers.Function.bind(this.processExtendedFeatureInfo, this);
             // use 'post' because filter could be a long string.
@@ -2034,7 +2032,7 @@
             oBroker.dispatchRequest(r, OpenLayers.Function.bind(this.parseMapTip, this));
         } else {
More information about the fusion-commits mailing list
