[fusion-dev] RFC 1: Use OpenLayers.Class and other prototypecapabilities
Paul Spencer pspencer at dmsolutions.ca
Fri Mar 21 12:10:18 EDT 2008
Julien, comments below.
On 21-Mar-08, at 11:55 AM, Julien-Samuel Lacroix wrote:
> Hi,
> I think the OpenLayer team has always been really open to suggestion
> to become a standard library of webmapping component. It's a safe
> bet to rely on it. Planning of reusing OpenLayers.Control is also a
> great plus since it prevent us of duplicating the effort.
> Are you thinking of using the Controls directly and adding them
> fusion-specific functions? or using OpenLayer.Handlers inside your
> own code like the Select widget was done?
I haven't thought this through yet, but it should be possible to
change Widgets to *be* OpenLayers.Control instances.  I need to figure
out how much change needs to be made to make this work.  There are
definitely some differences between Control and Widget that are
insignificant, others I have to think about a bit more.
Relying on Handlers was the first low-level attempt and preventing
duplication, and it certainly does work well, but if we can take it up
one more level and move some/most Widgets into the OpenLayers code
base, that would be awesome for both projects.
> About the initial problem, "Fusion is based on Jx and Jx is too big
> because of Prototype and Scriptaculous, if we remove Prototype, that
> will reduce the size". Will it be enough? What part of the 185kb is
> used by Prototype and Scriptacoulus?
That is the size of Prototype and Scriptaculous, compressed.  Jx is on
top of that.  Jx + Prototype + Scriptaculous compressed is 232 kb.  So
Jx is 47kb on top of whatever library we use - it also needs to be
slimmed down a bit if possible, but the big culprit is Prototype/
Scriptaculous.
Cheers
Paul
> Julien
> Paul Spencer wrote:
>> Jason,
>> that is correct.  In addition, it would make it much easier to
>> consider moving to a different GUI framework such as ExtJS
>> although  that is not something that we are thinking of doing.
>> Based on my work with OpenLayers, much of the functionality that
>> we  would be relying on was originally copied from Prototype (or at
>> least  inspired by Prototype) when OpenLayers removed its own
>> dependency on  Prototype.  While I haven't done a lot outside of
>> OpenLayers with that  framework, it is working very well for
>> OpenLayers and the API has not  changed in a while.  There is some
>> current work being done on the Ajax  support in OpenLayers that
>> will make it somewhat different from the  existing Prototype API
>> but I believe it will still work for our needs  and may in fact
>> improve it for us too :)
>> There is an alternative, which is to bring the essential parts of
>> Prototype (or equivalent) into the Fusion namespace so that we are
>> not  dependent on anything (for that at least).  However, this
>> would  duplicate code and functionality and I am not keen on
>> maintaining any  more code in Fusion than necessary.  As time goes
>> by, I am going to be  proposing even tighter integration with
>> OpenLayers (think  Fusion.Widget = OpenLayers.Control for instance).
>> An argument against tighter integration may be that we may want to
>> replace OpenLayers with another map management library at some
>> point.   However, I don't see anything on the block that is going
>> to compete  with OpenLayers at the moment and I don't feel that
>> this is a bad move  on our part.
>> Cheers
>> Paul
>> On 20-Mar-08, at 4:17 PM, Jason Birch wrote:
>>> So...
>>> This RFC is basically removing Fusion's explicit dependencies on
>>> Prototype, so that Jx is free to move to a different framework
>>> without
>>> disrupting Fusion?
>>> If so, sounds reasonable to me.
>>> Are these components in OpenLayers stable/enshrined enough that
>>> switching to that implementation will not incur the same risk of
>>> disruption?
>>> Jason
>>> -----Original Message-----
>>> From: fusion-dev-bounces at lists.osgeo.org
>>> [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Paul
>>> Spencer
>>> Sent: Thursday, March 20, 2008 12:49
>>> To: fusion-dev at lists.osgeo.org
>>> Subject: [fusion-dev] RFC 1: Use OpenLayers.Class and other
>>> I realize that we don't have a PSC yet, however I would like to
>>> start
>>> working as if we did have one and use the current membership of the
>>> dev mailing list to discuss major changes to Fusion.  We will be
>>> working to formalize a PSC as we grow the community around
>>> Fusion.  In
>>> the mean time, I have a major change that I would like to get
>>> community consensus on.
>>> If you are interested, please see the following RFC and comment on
>>> this list.
>>> http://trac.osgeo.org/fusion/wiki/FusionRfc1
>>> Cheers
>>> Paul
>>> __________________________________________
>>>   Paul Spencer
>>>   Chief Technology Officer
>>>   DM Solutions Group Inc
>>>   http://www.dmsolutions.ca/
>>> fusion-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>>   Paul Spencer
> Mapgears
> http://www.mapgears.com/
    Paul Spencer
More information about the fusion-dev mailing list
