[fusion-dev] Re: [fusion-users] fusion 1.1 planning
Mike Adair
madair at dmsolutions.ca
Thu May 8 09:45:12 EDT 2008
I am working on refactoring Fusion to be able to add in other OpenLayers
layer types and to be able to have more than one map in a MapGroup, I'm
probably about half-way there. I'm doin this work in the 'olcore'
sandbox (but I haven't got everything checked in until it works a little
better).
I also agree it would be a lot better to use the OL vector rendering and
styling tools.
Mike
Paul Spencer wrote:
> Mike would be better to comment, but I think he already has the code
> at least partially working.
> Paul
> On 7-May-08, at 3:25 PM, Julien-Samuel Lacroix wrote:
>> Hi,
>> Let's go that way then! :)
>> Did some work have already been done toward the support for other
>> OpenLayers types? This would probably be the first step toward the
>> Vector support. Is it still an idea or is there plan already?
>> Julien
>> Paul Spencer wrote:
>>> Hey Julien,
>>> there is already a CanvasTool class that provides client side
>>> vector capability on which you could create drawing and editing
>>> tools. I use the CanvasTool class as a mix-in to SelectPolygon (for
>>> instance).
>>> I would love to get this updated (or replaced) to use Layer.Vector
>>> and provide widgets for the vector editing stuff but I don't know
>>> if I will have time - if you are willing to work on it, I would
>>> work with you on it.
>>> Cheers
>>> Paul
>>> On 6-May-08, at 3:20 PM, Julien-Samuel Lacroix wrote:
>>>> > * implement support for other OpenLayers layer types through the
>>>> > MapGroup tag in the ApplicationDefinition
>>>> Hi,
>>>> What a coincidence! :) After demo-ing Fusion to a client last
>>>> Friday, a question raised. Is it possible to use vector edition
>>>> features from OpenLayers inside Fusion?
>>>> Currently it's not possible. From what you write here, it would be
>>>> possible to add OpenLayers layers on the top of a Fusion map.
>>>> Could we then add a Vector layer and use the vector edition
>>>> controls? I guess that would need a new widget for vector edition,
>>>> right?
>>>> Can you give us more details?
>>>> Julien
>>>> Mapgears
>>>> http://www.mapgears.com/
>>>> _______________________________________________
>>>> fusion-dev mailing list
>>>> fusion-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>>> Paul Spencer
>>> Chief Technology Officer
>>> DM Solutions Group Inc
>>> http://www.dmsolutions.ca/
>> Mapgears
> Paul Spencer
More information about the fusion-dev
