[fusion-dev] multilevel legend tree with mapserver
Paul Spencer
pspencer at dmsolutions.ca
Fri Nov 14 06:58:25 EST 2008
this is a moderated list so you need to be registered to post - I've
let your posts through but please consider joining the list, it looks
like you have some good stuff to contribute!
I would like to get some feedback from some other mapserver fusion
users on this approach. I would personally have attempted a metadata-
based approach to keep all the configuration in the map file. What do
others think?
Regardless, multi-level grouping would be nice to support for
mapserver in some fashion since the client-side already handles it for
MapGuide.
Cheers
Paul
On 14-Nov-08, at 4:11 AM, klementszabolcs wrote:
> Hi i make multilevel tree in Mapserver/php/LoadMap.php.
> when make a mapfile.grp in the same directory where mapfile.map
> exists,
> then the "groups":[] piece in loadmap json result change with the
> grp file content.
> the grp file sample:
> "groups":[
> { "groupName
> ":"main
> ","legendLabel
> ":"xxx
> ","uniqueId
> ":"main
> ","displayInLegend
> ":true
> ,"expandInLegend
> ":false
> ,"layerGroupType
> ":"","parentUniqueId
> ":"","parent":"","visible":true,"actuallyVisible":0
> "groupName
> ":"sample
> ","legendLabel
> ":"sample
> ","uniqueId
> ":"sample
> ","displayInLegend
> ":true
> ,"expandInLegend
> ":false
> ,"layerGroupType
> ":"main","parent":"","visible":true,"actuallyVisible":0
> the change in loadmap.php:
> from line 280:
> $mapObj->groups = array();
> $aGroups = $oMap->getAllGroupNames();
> //multilevel tree
> $groupfile=substr($_REQUEST['mapfile'], 0,
> strpos($_REQUEST['mapfile'], ".")).'.grp';
> if (file_exists($groupfile)) {
> $groupstr=file_get_contents($groupfile);
> }else{
> foreach($aGroups as $groupName) {
> $aLayerIndexes = $oMap->getLayersIndexByGroup($groupName);
> if (count($aLayerIndexes) > 0) {
> array_push($mapObj->groups, getGroupObject($oMap-
> >getLayer($aLayerIndexes[0])));
> //tree end
> $retstr=var2json($mapObj);
> if (isset($groupstr)) {
> $retstr=str_replace('"groups":[]',$groupstr,$retstr);
> //echo $groupstr;
> echo $retstr;
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-dev
