[fusion-dev] [Code
Review]http://trac.osgeo.org/fusion/attachment/ticket/344/patch344.patch
Paul Spencer
pspencer at dmsolutions.ca
Thu Dec 3 11:07:22 EST 2009
I'm not keen on changing OpenLayers code without a patch going to OpenLayers, otherwise this will just break the next time we update OpenLayers. Is there not some way to use the OpenLayers API to modify the zIndex of the redline layer to achieve the same effect?
Cheers
Paul
On 2009-12-03, at 4:01 AM, Arthur Liu wrote:
> Hi all,
> Would you please review http://trac.osgeo.org/fusion/attachment/ticket/344/patch344.patchfor fixing http://trac.osgeo.org/fusion/ticket/344 Object drawn by Redline with consumer map didn't display until Zoom map?
> [Description]
> 1. Open one flexible web layout with commercial layers.
> 2. Redline -> Draw point.
> Results:
> Nothing shown.
> Zoom in or out, the point drawn displayed.
> Object drawn by Spatial Query has the same issue.
> [Resolution]
> 1. In redline.js, added the evt.feature.layer.redraw() to redraw the redline layer after feature added.
> 2. In OpenLayers.js, updated setLayerZIndex method to make sure redline layer can display at the top of map layers, regardless there are more than one overlay layers.
> Thanks,
> Arthur
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-dev
