[fusion-dev] Integrate Commercial Map Service Layers Problem
Zak James zjames at dmsolutions.ca
Fri Jul 17 08:00:43 EDT 2009
That's right. The Yahoo and Virtual Earth layer types need to be added. There is also some other code needed to make everything work as advertised that I haven't yet committed.
Sorry for the confusion.
Zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
http://research.dmsolutions.ca
-----Original Message-----
Sent:  17/07/2009 06:22:10
To: Arthur Liu
Cc: Jason Birch; fusion-dev at lists.osgeo.org; Zac Spitzer; Zak James
Subject:  Re: [fusion-dev] RE: Integrate Commercial Map Service Layers Problem
It was Zak :)  I suspect that the OpenLayers build included in Fusion
does not contain all the commercial map types, I will check with Zak
on this today.
Paul
On 17-Jul-09, at 3:16 AM, Zac Spitzer wrote:
> I didn't do the wiki page  :)
> fusion uses a a profile to reduce the size of the file, all of OL is
> like 1mb..
> http://trac.openlayers.org/wiki/Profiles
> the build script for fusion will have a .cfg file which is called
> during the
> build process, you will need to locate that in the fusion tree and add
> in the layers you need
> http://trac.osgeo.org/fusion/browser/trunk/fusion.cfg
> remember you cannot use commerical maps with a password protected
> site,
> subject to licensing
> z
> On Fri, Jul 17, 2009 at 4:55 PM, Arthur Liu<arthur.liu at autodesk.com>
> wrote:
>> Thanks for your reply.
>> I am using the lasted revision but still have that problem.
>> Regards,
>> Arthur
>> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
>> Sent: Friday, July 17, 2009 12:02 PM
>> To: Arthur Liu; fusion-dev at lists.osgeo.org
>> Subject: RE: Integrate Commercial Map Service Layers Problem
>> Hey Arthur,
>> Are you using Fusion trunk?  I believe that there were some defects
>> or maybe missing code that prevented this from working with
>> previous versions.
>> Zac recently updated the wiki page on this:
>> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
>> Jason
>> ________________________________
>> From: Arthur Liu
>> Sent: Thursday, July 16, 2009 8:18 PM
>> Subject: [fusion-dev] Integrate Commercial Map Service Layers Problem
>> Is there anyone successfully integrated Yahoo or Virtual Earth in
>> MapGuide?
>> I always got failed with error message as
>> "OpenLayers.Layer[this.layerType](...)" is not a constructor,
>> unless I add the script for openlayers(<script type="text/
>> javascript" src="http://www.openlayers.org/api/OpenLayers.js"></
>> script>) into the index.html in MG template .  Any suggestions and
>> comments are very appreciated. Thanks.
>> BTW, Google Layers doesn't has such kind of problem.
>> Regards,
>> Arthur
>> fusion-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
    Paul Spencer
    Chief Technology Officer
    http://research.dmsolutions.ca/
More information about the fusion-dev mailing list
