[fusion-dev] RE: Ticket: Fusion reports unreadable error message
Christine Bao
Christine.Bao at autodesk.com
Mon Jul 20 22:22:13 EDT 2009
Hi Paul,
Currently Fusion actually fires an error event.
Fusion.js:
if (r.status >= 400) {
Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
'xml2json: invalid XML document: ' + r.statusText + " : " + r.request.url));
return;
This will fire an error event, and the event is registered in MapGuide.
MapGuide template:
Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
var fusionError = function(eventId, error) {
alert('Fusion Error: \n' + error.toString());
In this way, I can handle the error message in MapGuide template, parse them and only show the exception message. This solution will not affect fusion. How do you like this idea?
Thanks & regards,
Christine
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Tuesday, July 21, 2009 3:27 AM
To: Jason Birch
Cc: Christine Bao; fusion-dev at lists.osgeo.org
Subject: Re: Ticket: Fusion reports unreadable error message
This sounds more application-specific than I am willing to put into
the library as core functionality. So to accommodate this, I would
prefer that we expose 'extended' error conditions through event
notifications that developers can use to implement their own handling
system. In this case, Fusion would never alert an error but rather
would trigger error events (some of this happens already) and pass
both basic and extended information.
In this case, Christine's patch should be modified to fire an error
event instead of an alert. Perhaps that is beyond the scope of the
current change :)
Paul
On 20-Jul-09, at 2:13 PM, Jason Birch wrote:
> I'm not sure. I was initially going to suggest that, but I often
> don't get trouble reports until after an application has been signed
> off, moved to production, etc... I'd hate to leave a debug flag
> turned on in production if it had performance implications made the
> interface totally developer-centric, and I'd be concerned that
> calling the config option "debug" would lead to this.
> If it was called "extendedErrors" or something like that it might be
> better? Or if there were different debug levels (none, error,
> information)?
> Another option would be a link that says "Email Problem Report"
> where user can fill in information about what they were doing, and
> all debug info is automatically added to the report. :)
> Jason
> From: Paul Spencer
> Sent: Monday, July 20, 2009 10:56 AM
> Would a configurable option to run in 'debug' mode vs production mode
> be practical for this sort of this? It could be added to the existing
> config.json and used in various places for reporting problems vs
> either suppressing them or providing less ominous looking errors ...
> Paul
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-dev
