[fusion-dev] Patch for #271
http://trac.osgeo.org/fusion/attachment/ticket/271/BasemapSwitcher.patch
review
Jason Birch
Jason.Birch at nanaimo.ca
Wed Jul 29 20:27:00 EDT 2009
For my users, "None" just wouldn't make sense. They don't understand what a base map is, and would want an easy to use chooser. This is what I would ideally like to be able to do:
"Satellite" (Google)
"Streets" (MapGuide map definition with tile layers only)
"Parcels" (MapGuide map definition with tile layers only)
On top of this base map choice, I would layer a MapGuide dynamic/singleTile map.
Combining tile layers into a dynamic MapGuide map is dangerous, and limits you from having multiple mapguide-based tile map sources in the same map.
Jason
Sent: Tuesday, July 28, 2009 10:17 PM
To: Jason Birch; fusion-dev at lists.osgeo.org
Subject: RE: [fusion-dev] Patch for #271 http://trac.osgeo.org/fusion/attachment/ticket/271/BasemapSwitcher.patch review
Hi Jason,
Thanks for your comment. Actually, the controls items would be :
- Satellite (by Google)
- Composite (by Google)
- None
If the user selected the “None” item, the MapGuide map will be set as basemap, and it just looked like the original MapGuide map without any commercial maps.
I am not sure if I totally understand your question, if not, please point it out.
Thanks,
Arthur
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, July 28, 2009 11:11 PM
To: fusion-dev at lists.osgeo.org
Cc: Arthur Liu
I unfortunately don't really understand the code, so this might be a stupid question.
With this control, does it allow the map developer to configure a set of basemaps including both MapGuide tiled maps and commercial maps, and switch between them? For instance, could I present the user with a choice of the following base maps via this control?
- Parcels (mine)
With MapGuide tile layers, it's not really sustainable to keep them in the same map as untiled layers (any changes to the untiled layers triggers a cache rebuild) so it would be nice to be able to define both a MapGuide single tile overlay and a MapGuide base map as separate items.
Jason
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Arthur Liu
Sent: Monday, July 27, 2009 8:29 PM
Subject: [fusion-dev] Patch for #271 http://trac.osgeo.org/fusion/attachment/ticket/271/BasemapSwitcher.patch review
Would you please review the patch for ticket 271( http://trac.osgeo.org/fusion/ticket/271 ) at http://trac.osgeo.org/fusion/attachment/ticket/271/BasemapSwitcher.patch ?
Description :
Currently, fusion support Google, Yahoo and Virtual Earth services as basemaps shown behind the overlaid MapGuide layers. However there's no proper widget to switch basemaps in MapGuide. That means there's no way for end-user to change the basemaps. This widget will help end-user to control the commercial base maps(turn on/off commercial basemaps or switch the basemaps).
Thanks,
Arthur
More information about the fusion-dev
