[fusion-dev] can't browse source code on the wiki
Paul Spencer pspencer at dmsolutions.ca
Tue Mar 31 11:01:21 EDT 2009
the official response on this that the php version on the osgeo server
is not high enough to enable this at this time.  A ticket is being
raised with SAC to see if there is some way to fix this.  In the mean
time, you can see the source though:
http://svn.osgeo.org/fusion/trunk/layers/MapGuide/php/Common.php
but its not as nice (no line numbers or revision history)
Cheers
Paul
On 30-Mar-09, at 10:49 PM, Zac Spitzer wrote:
> is there a reason why fusion trac doesn't allow viewing code?
> ie here
> http://trac.osgeo.org/fusion/browser/trunk/layers/MapGuide/php/Common.php
> z
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-dev mailing list
