[fusion-dev] RE: [fusion-users] MapServer Legend Icons
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Fri Nov 6 09:33:03 EST 2009
Thanks Paul for the welcome and the advice for getting a MapGuide
install setup for testing. I'm really looking forward to contributing to
the project. I was on the site looking for guidelines and didn't find
anything. You do have some pages up but there is not content yet. Does
anyone have any recommendations or best practices that I should be aware
of? I just want to make sure that I meet any standards that have been
set and that my contributions are received well. Thanks.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Thursday, November 05, 2009 7:27 PM
To: Nolte, Tim
Cc: Paul Spencer; fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] MapServer Legend Icons
Hi Tim,
Welcome to the project. If your interested you can also download a live
cd of MapGuide Open source. (http://mapguide.osgeo.org/node/127) and run
it in vmware. If your interested. It's a nice way to see how fusion
works with both platforms and it will help to make sure that when you
fix an issue on one platform that it doesn't expose an issue on the
other so it's a good idea to have setup anyhow.
Cheers
Paul D (Not Paul S) :)
On Thu, Nov 5, 2009 at 4:33 PM, Nolte, Tim
<Tim.Nolte at ipcswirelessinc.com> wrote:
Paul,
Excellent! Thank you very much. I've making some good head way
on the
whole Legend issue, especially when using multiple maps within a
map
group. I'm going to switch over to a single map in the map group
and see
what results I get also. I'm happy to be able to submit changes
to the
MapServer side of the project. I hope that my work will help
others that
are already using MapServer adopt Fusion as their framework of
choice.
- Tim
iPCS Wireless, Inc.
Kentwood, MI 49512
PCS: 616-706-2438
Fax: 616-554-6484
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Thursday, November 05, 2009 3:46 PM
To: Nolte, Tim
Cc: fusion-users at lists.osgeo.org
Hi Tim,
the project is not dead but I don't know how many folks are
using it
right now. I know that MapGuide is actively using it and the
Autodesk
team there is actively finding and fixing bugs related to the
MapGuide
support. DM Solutions is also actively using and developing the
framework and the MapServer support.
I have added you as a committer, welcome aboard!
Cheers
Paul
On 2009-11-05, at 3:03 PM, Nolte, Tim wrote:
> Is this forum and/or project dead? How many people are
actually using
> this or developing for it?
> Well, on a good note I finally got a somewhat working solution
by
> basically forgetting about trying to rely on $_SESSION and
basically
> copied a bunch of the LoadMap code that sets up the Scale
Ranges
> over to
> the LoadScaleRanges script. I also changed the script to also
not rely
> on the $_SESSION to tell it what mapfile it is supposed to use
and
> basically copied the code in LoadMap that sets up the SESSION
based
> map.
> There is still the issue of the Legend being sorted backwards,
the
> Legend icons not all updating properly when zooming in, as
well as an
> issue with the map layers not being stacked in the right
order. I'm
> plugging away at this. It would be really nice if no one else
is
> really
> working on MapServer specific development that I could start
> submitting
> to the SVN or somehow my changes could get approved to be
taken into
> the
> project. I'll hate to have to use a diff utility every time
there is
> an
> update and have to fix my code so that things still work.
Thanks to
> anyone that is actually reading this, if there is anyone out
there.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> From: fusion-users-bounces at lists.osgeo.org
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of
Nolte, Tim
> Sent: Wednesday, November 04, 2009 4:08 PM
> To: Paul Spencer
> Subject: RE: [fusion-users] MapServer Legend Icons
> Paul,
> I attempted this, however what I found was that the way the
loading
> process happens it is not enough to just stick the scale
ranges into
> the
> PHP $_SESSION. I'm finding that all of the individual maps in
many
> cases
> don't yet exist in the SESSION when the corresponding
> LoadScaleRanges is
> called. Do you have any thoughts on how Fusion could be
changed to
> only
> call LoadScaleRanges 1 time after all of the LoadMap calls
have
> finished? I think this could be the fix. The only other option
I see
> is
> that the whole scale ranges creation process needs to be
duplicated in
> LoadScaleRanges script. I'm not sure but perhaps this
functionality
> needs to be added to the Utilities script?
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
Paul
> Spencer
> Sent: Monday, October 26, 2009 3:07 PM
> To: Nolte, Tim
> Ohhhhh - light goes on - doh! You have 6 maps in the same map
group!
> This will need a bit of work :) We need to modify the
scale_ranges
> array in the session so that it is subdivided by map name.
LoadMap
> needs to set
> $_SESSION['scale_ranges'][$mapName]
> and LoadScaleRanges needs to use the same thing when
referencing it.
> Do you think you could make these changes and test? If it
works, I'll
> file the bug and commit. If you don't want to try first, I
can take a
> stab at it and commit but I'm not really set up to test right
now.
> Thanks Tim
> Paul
> On 2009-10-26, at 2:39 PM, Nolte, Tim wrote:
>> What I am seeing with Firebug is that there are 6 calls to
>> LoadMap.php,
>> which are my 5 main maps and 1 overview map. After the 5th
>> LoadMap.php
>> call then the LoadScaleRanges.php calls begin, there are 5
calls. One
>> thing that I noticed also is that the MapTips are not working
and
>> what
>> is being POSTed to the MapTip.php script is the wrong map for
the
>> layer
>> that I've selected for MapTips. Seems like there could be a
problem
>> with
>> using the SESSION if the LoadMap.php is not adding something
to the
>> SESSION to directly link the call to the LoadScaleRanges.php
so that
>> it's not pulling the wrong scale_ranges. Is there any
debugging
>> information that I can send?
>> - Tim
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS: 616-706-2438
>> Fax: 616-554-6484
Paul
>> Spencer
>> Sent: Monday, October 26, 2009 11:30 AM
>> To: Nolte, Tim
>> Hi Tim,
>> The legend icon stuff is working in another project that Paul
>> Deschamps is working on, he has multiple map files and a menu
for
>> changing between them. The legend does appear to update
correctly
>> when changing maps.
>> The way it *should* work is that LoadMap.php populates a
session
>> variable 'scale_ranges' with an array of each scale range of
each
>> class of each layer. LoadScaleRanges.php uses this array to
get the
>> class for each scale range and draw the icon at the
appropriate scale
>> for that class and then combines them all into a single
image, and
>> returns a set of CSS offset values for use by the legend - so
each
>> scale range has the same image source but different offsets.
>> I suspect what is going wrong is that the scale_ranges array
is
>> somehow the wrong one. We need to know what sequence is
causing
>> this. Is LoadScaleRanges being called before LoadMap
finishes? Or
>> are you programmatically changing maps while loading them or
between
>> loading and calling LoadScaleRanges?
>> Cheers
>> Paul
>> On 2009-10-26, at 10:38 AM, Nolte, Tim wrote:
>>> Last week I had posted about a problem with my legend icons
not
>>> showing
>>> up. I have multiple MapServer mapfiles defined. I'm not sure
if the
>>> problem I'm having is solely related to having multiple
mapfiles or
>>> that
>>> I recently updated to the latest Fusion trunk. I can say
that the
>>> problem with the legend icons is because of an error in
>>> layers\MapServer\php\LoadScaleRanges.php, the section that
it is
>>> having
>>> a problem with is:
>>> $oImg = $oClass->createLegendIcon($nIconWidth,
$nIconHeight);
>>> This is failing with the error:
>>> Fatal error: Call to a member function
createLegendIcon() on a
>>> non-object
>>> If I change the code to make sure that '$oClass' is not NULL
then
>>> legend
>>> icons do get created but they are not being created
correctly. I'm
>>> not
>>> sure if this is something where I need to use a different
built-in
>>> function to use one of the default Fusion layer icons? If
anyone has
>>> any
>>> ideas it would be a big help.
>>> - Tim
>>> iPCS Wireless, Inc.
>>> Kentwood, MI 49512
>>> PCS: 616-706-2438
>>> Fax: 616-554-6484
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://research.dmsolutions.ca/
> Paul Spencer
Paul Spencer
Paul Deschamps
Applications Specialist
DM Solutions Group Inc.
Office: (613) 565-5056 x28
pdeschamps at dmsolutions.ca
http://www.dmsolutions.ca
More information about the fusion-dev
