[fusion-dev] RE: [fusion-commits] r1966 - trunk/lib
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Mon Nov 9 14:09:26 EST 2009
Sounds good. Just wanted to bring it up. Perhaps I should have just made
the comment on TRAC directly instead of here. If that is the
recommendation please just say the word. It's interesting that you say
that this should only apply to MapGuide installs and shouldn't affect
MapServer installs. Not sure but I was actually getting JavaScript
errors in Firebug with these code changes.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Monday, November 09, 2009 1:55 PM
To: Nolte, Tim
Cc: fusion-dev at lists.osgeo.org
Subject: Re: [fusion-dev] RE: [fusion-commits] r1966 - trunk/lib
I think Zak is working on a more generic solution here. The code here
should not have affected MapServer, it should only be invoked when the
application definition is being loaded from a URL that starts with
Library:// which indicates it is stored in a MapGuide repository. The
original issue that was being solved was how to automatically add
commercial mapping APIs to an application - this required knowing if
any of them are referenced in an Application Definition which required
pre-requesting the ApplicationDefinition - which, when stored in a
MapGuide repository issues an authentication challenge unless using a
pre-established session - which is what this commit was about.
Zak is going to try refactoring this to work generically for MapServer
and MapGuide by moving the code so that it runs at a slightly later
time in initialization.
Cheers
Paul
On 2009-11-09, at 1:49 PM, Nolte, Tim wrote:
> FYI, this bug fix breaks in MapServer installs. I see that it has been
> hard-coded to 'layers/MapGuide/php/CreateSession.php' which isn't
> valid
> for MapServer. Seems like somehow we need a more generic way for
> creating the session. I'm not familiar with how MapGuide works with
> sessions but for the most part we are looking at PHP sessions which
> should be pretty standard. What are the thoughts here?
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> From: fusion-commits-bounces at lists.osgeo.org
> [mailto:fusion-commits-bounces at lists.osgeo.org] On Behalf Of
> svn_fusion at osgeo.org
> Sent: Sunday, November 08, 2009 10:16 PM
> To: fusion-commits at lists.osgeo.org
> Subject: [fusion-commits] r1966 - trunk/lib
> Author: liuar
> Date: 2009-11-08 22:15:36 -0500 (Sun, 08 Nov 2009)
> New Revision: 1966
> Modified:
> trunk/lib/fusion.js
> Log:
> Fixed http://trac.osgeo.org/fusion/ticket/300
> pre-create a session to avoid the unauthorized dialog, which is a
> defect
> of safari and chrome.
> Modified: trunk/lib/fusion.js
> --- trunk/lib/fusion.js 2009-11-06 16:05:28 UTC (rev 1965)
> +++ trunk/lib/fusion.js 2009-11-09 03:15:36 UTC (rev 1966)
> @@ -227,7 +227,8 @@
> initialize : function(options) {
> options = options || {};
> var sessionIdParam = this.getQueryParam('Session');
> - this.sessionId = sessionIdParam || (options.sessionId ||
> null);
> + // Override the pre-created sessionId by user
> specified sessionId(if exist)
> + this.sessionId = sessionIdParam ||
> options.sessionId || this.sessionId;
> if (options.applicationDefinitionURL) {
> this.applicationDefinitionURL =
> options.applicationDefinitionURL;
> @@ -252,11 +253,11 @@
> this.sScriptLang = "";
> - * if the application has been loaded from the
> same
> host as
> - * fusion is installed in, then technically we
> don't need to
> - * use the redirect script because we conform to
> the
> - * Same Origin Policy for XmlHttpRequest to work.
> + * if the application has been loaded from the
> same host as
> + * fusion is installed in, then technically we
> don't need to
> + * use the redirect script because we conform to
> the
> + * Same Origin Policy for XmlHttpRequest to
> work.
> var test =
> window.location.protocol+'//'+window.location.host;
> var configUrl = 'config.json';
> //if (this.fusionURL.indexOf(test,0) == 0) {
> @@ -1147,7 +1148,7 @@
> var fusionURL = r + Fusion.getFusionURL() + configUrl;
> - var xhr = new XMLHttpRequest();
> + var xhr = getXmlHttpRequest();
> xhr.open("GET", fusionURL, false);
> xhr.send(null);
> @@ -1174,7 +1175,7 @@
> Fusion.configuration.mapguide.mapAgentUrl = s +
> 'mapagent/mapagent.fcgi';
> return Fusion.configuration.mapguide.mapAgentUrl;
> var addElement = function(element) {
> if (!element) {
> @@ -1188,29 +1189,50 @@
> document.writeln('<script src="' + src + '"><\/script>');
> - if(navigator.userAgent.indexOf("MSIE")>0 ||
> navigator.userAgent.indexOf("Firefox")>0){
> - var appDefUrl =
> Fusion.getQueryParam('ApplicationDefinition');
> - if(appDefUrl){
> - var mapAgentUrl = getAgentUrl();
> - xhr.open("GET", mapAgentUrl +
> OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGu
> ide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml", false);
> - xhr.send(null);
> - var appDefXML = xhr.responseXML.documentElement;
> - if(appDefXML){
> - var googleElement =
> appDefXML.getElementsByTagName("GoogleScript")[0];
> - var yahooElement =
> appDefXML.getElementsByTagName("YahooScript")[0];
> - var veElement =
> appDefXML.getElementsByTagName("VirtualEarthScript")[0];
> + var getXmlHttpRequest = function(){
> + try { return new XMLHttpRequest(); }
> + catch (e) { try { return new
> ActiveXObject('Msxml2.XMLHTTP'); }
> ActiveXObject('Microsoft.XMLHTTP'); }
> + catch (e) { return null; }}}
> + * Function: createSessionId
> + * Pre-create a session to avoid the 401 Unauthorized dialog
> + var createSessionId = function(){
> + xhr.open("GET",
> Fusion.fusionURL+"layers/MapGuide/php/CreateSession.php",false);
> + xhr.send(null);
> + var o;
> + eval('o='+xhr.responseText);
> + Fusion.sessionId = o.sessionId;
> + createSessionId();
> + var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
> + if(appDefUrl){
> + var xhr = new getXmlHttpRequest();
> + var mapAgentUrl = getAgentUrl();
> + xhr.open("GET", mapAgentUrl +
> %2Fxml&SESSION="+
> Fusion.sessionId, false);
> + xhr.send(null);
> + var appDefXML = xhr.responseXML.documentElement;
> + if(appDefXML){
> + var googleElement =
> + var yahooElement =
> + var veElement =
> - addElement(googleElement);
> - addElement(yahooElement);
> - addElement(veElement);
> + addElement(googleElement);
> + addElement(yahooElement);
> + addElement(veElement);
> fusion-commits mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-commits
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-dev
