[fusion-dev] Creating Vector Points on the Map from Task Pane
Arthur Liu arthur.liu at autodesk.com
Mon Nov 30 01:39:31 EST 2009
Hi all,
Would you please review http://trac.osgeo.org/fusion/attachment/ticket/306/Patch306.patch for fixing http://trac.osgeo.org/fusion/ticket/306  Legend panel is empty with Raster/WMS data source?
Comments: In the original implementation, for raster layer which doesn't contain any styles, the legend icon is set to imgDisabledLayerIcon, which should be imgLayerRasterIcon actually.
Thanks,
Arthur
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20091129/ecc6a5a5/attachment.html
More information about the fusion-dev mailing list
