[fusion-dev] Simple Selection
JP_Staff
jpps975 at sbcglobal.net
Wed Oct 7 11:51:52 EDT 2009
To All,
I am slowly getting a handle on using the Fusion & OpenLayers, although I am
still a newbie. I have a question concerning map selection in Fusion. When
using Mapguide with basic layouts I was able to select an item(feature) on
the map by setting the calling the mapframe.setselectionxml(). In fusion how
do I go about this. I have tried the following with a simple example, but I
am ending up with AGF text is invalid.
My layout is the following
| |Frame 1 | |Frame2 | |FRame3 | |
| |Map FRame | |
My selection is generated from the Frame 3 which is calling Map FRame in
order to show a selection on the map.
Here is the javascript I am using for a test
function selectMap() {
var Fusion = parent.parent.viewerFrame.Fusion;
var mapWidget = Fusion.getWidgetById('Map');
var options = {};
options.maxFeatures = 10;
options.layers = "PMP Points";
options.filter = "ProjectAliasID = 2008.1967";
mapWidget.query(options);
Thanks for any help,
Jean-Paul
View this message in context: http://n2.nabble.com/Simple-Selection-tp3782639p3782639.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev
