[fusion-dev] Error with displaying google imagery
Zak James
zjames at dmsolutions.ca
Wed Sep 30 19:15:11 EDT 2009
JP,
I neglected to mention that you should back up the original folder because you will need to move the slate template from the install inside the svn copy to continue using it.
Zak
-----Original Message-----
Sent: 30/09/2009 18:59:29
Subject: RE: [fusion-dev] Error with displaying google imagery
JP,
Are you sure you have replaced the fusion folder installed by mapguide 2010 with a fresh svn version of fusin trunk?
Zak
Sent: 30/09/2009 17:09:56
Subject: [fusion-dev] Error with displaying google imagery
Hi All,
I am a newbie to this site, and so far have gained alot of great
information. I am running into an issue when loading google maps in my
current fusion template. I am currently using MG2010, and using the
slate.html template. I am loading all layers dynamically to the map using
MaestroAPI.I have followed the implementation of the
http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
for overlaying google imagery into my current map. I have modified my
index.html file to include the google javascript file reference and I am
currently using the fusion.js file. I have updated my current map definition
to include the google reference here is a snippit of my map def
-95.854896545410156
34.845642892061733
10000000
Google
google
G_HYBRID_MAP
MapGuide
true
false
true
EPSG:900913
{0}
When loading the map I recieve the following javascript error
(1) this.mapWidget.oMapOL is null
(2)legend.currentRange is null
(3)lots of Object reference set to null
Then the layers load in the legend, the toolbar is not visible above the
map.
My layers load on the map, if I pan the map I am able to view the google
base map, then it is covered by my other layers. I have found in the
Legend.js where the issue is returning null, but I can't seem to locate the
error wherethis.mapWidget.oMapOL is null, I am assuming it is in the
openlayers.js, any help or guidance is much appreciated.
THanks,
Jean-Paul
View this message in context: http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3745357.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
fusion-dev mailing list
fusion-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev
