[fusion-dev] Raster layer's icon displayed as disabled icon in
MapGuide
Arthur Liu
arthur.liu at autodesk.com
Mon Feb 8 00:14:09 EST 2010
Hi Mike,
Thank you for the test, I have updated the legend.js at http://trac.osgeo.org/fusion/attachment/ticket/306/RasterLayerIconInLegend.2.patch
Because MapGuide raster layer doesn't contain the style so the else block will not be executed. So I move it out of the else block. Would you please confirm that?
Thanks,
Arthur
-----Original Message-----
Sent: Friday, February 05, 2010 2:12 AM
To: Arthur Liu
Cc: fusion-dev at lists.osgeo.org
Subject: Re: [fusion-dev] Raster layer's icon displayed as disabled icon in MapGuide
Arthur,
I tested it and it breaks the Legend for MapServer, which uses the
style.iconOpt property to set the legend icon from a sprite. (It does
set a raster layer icon properly though).
I think you need to re-do the logic in the if statements, probably going
back to something like the original:
if (!style) {
} else {
if (layerType...)
and put back in the style.iconOpt.url logic.
Mike
Arthur Liu wrote:
> Hi all,
> This review lasts such a long time but I still got no response, I have
> updated the patch at
> http://trac.osgeo.org/fusion/attachment/ticket/306/RasterLayerIconInLegend.patch
> and could someone test it on MapServer please?
> Regards,
> Arthur
> *From:* fusion-dev-bounces at lists.osgeo.org
> [mailto:fusion-dev-bounces at lists.osgeo.org] *On Behalf Of *Arthur Liu
> *Sent:* Monday, November 30, 2009 2:40 PM
> *To:* fusion-dev at lists.osgeo.org
> *Subject:* RE: [fusion-dev] Creating Vector Points on the Map from
> Task Pane
> Hi all,
> Would you please review
> http://trac.osgeo.org/fusion/attachment/ticket/306/Patch306.patch for
> fixing http://trac.osgeo.org/fusion/ticket/306 Legend panel is empty
> with Raster/WMS data source?
> Comments: In the original implementation, for raster layer which
> doesn't contain any styles, the legend icon is set to
> imgDisabledLayerIcon, which should be imgLayerRasterIcon actually.
> Thanks,
> Arthur
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
madair at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
More information about the fusion-dev
