[fusion-dev] RE: [fusion-users] v2.0.0 release candidate available
Jason Birch jason at jasonbirch.com
Thu Mar 25 22:09:00 EDT 2010
On 1.1, I recently saw a similar (but probably not same) problem when I had
a map with an invisible layer at the root of the legend tree.  Also had
problems when the legend label _was_ blank in the MapDefinition, and when I
had layers with undefined min or max scales.  I think.  Didn't spend the
time putting together a reproducible test case because 1.1 is so old and I
had workarounds.
I wouldn't be surprised if this was hard to troubleshoot without a package
(data/layers/map/appdef) that demonstrates the problem.
On 25 March 2010 12:57, Berdel, Brian wrote:
> No problem
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20100325/c9a7fa7b/attachment.html
More information about the fusion-dev mailing list
