[fusion-dev] Re: Widgets Conflict
pdescham49
pdescham49 at gmail.com
Wed Oct 20 11:18:10 EDT 2010
I have run into this situation before. But the solutions eludes me right
now. Unfortunately at the moment I can not devote the time you require. You
should perhaps post to the list and see if anyone can assist.
Paul
On Wed, Oct 20, 2010 at 3:56 AM, Edi.Karadumi [via OSGeo.org] <
ml-node+5653820-1232234241-297997 at n2.nabble.com<ml-node%2B5653820-1232234241-297997 at n2.nabble.com>
> wrote:
> i have customized two widgets in fusion, the select widget and created a
> search widget or better adapted the search widget to work for mapserver. Now
> i have a problem when i use the search widget i use
> this.getMap().query(options)
> so i can hilite and zoom to the result of the search. At this point the
> selection_change event i called,
> so i get the result of my search but the event in the selection widget in
> selectionpanel.js i called to so i get a conflict between widgets. can you
> help me how to zoom to a specific feature (the result of the search) without
> the this.getMap().query(options), or better if is there any command to tell
> fusion that while search widget is executing, no other widgets should be
> executed. i have read something about a command activateTool or something to
> dont call other widgets while a widget is active, but i cant make it to
> function properly.
> Best Regards
> Edi Karadumi
> This email was sent by Edi.Karadumi<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=user_nodes&user=182671>(via Nabble)
> Your replies will appear at
> http://osgeo-org.1803224.n2.nabble.com/Widgets-Conflict-tp5653820p5653820.html
> To receive all replies by email, subscribe to this discussion<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=subscribe_by_code&node=5653820&code=cGRlc2NoYW00OUBnbWFpbC5jb218NTY1MzgyMHwtMTYyODEzMzgzNw==>
Paul Deschamps
Applications Specialist
DM Solutions Group Inc.
Office: (613) 565-5056 x28
pdeschamps at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Widgets-Conflict-tp5653820p5655317.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev
