[fusion-dev] Re: Jx API Update
Edi.Karadumi
edikaradumi at gmail.com
Wed Sep 15 08:34:18 EDT 2010
For the moment the map is not on the web, but ill give you the link as soon
as possible, cuz im working on that. I think its a projection problem. It
seems that the map draws but it does not shows cuz in the status bar i see
negative coordinates, while i have positive ones. For the moment i can post
only parts of the code. Is any element missing in my applicationdefinition
in the map part?
<MapSet xsi:type="MapSetType">
<MapGroup id="gmap" xsi:type="MapType">
<Map xsi:type="MapLayerType">
<Type>MapServer</Type>
<SingleTile>true</SingleTile>
<Extension>
<!--<MapFile>/ms4w/apps/gmap/htdocs/gmap75.map</MapFile>-->
<MapFile>/ms4w/apps/gmap/htdocs/csharptutorial.map</MapFile>
</Extension>
</Map>
</MapGroup>
</MapSet>
On Tue, Sep 14, 2010 at 3:44 PM, Paul Deschamps [via OSGeo.org] <
ml-node+5530313-1191200985-182671 at n2.nabble.com<ml-node%2B5530313-1191200985-182671 at n2.nabble.com>
> wrote:
> Edi,
> If you perhaps shared a link to your application we could better direct you
> to where the issue is.
> Cheers
> Paul D.
> On Tue, Sep 14, 2010 at 3:12 AM, Edi.Karadumi <[hidden email]<http://user/SendEmail.jtp?type=node&node=5530313&i=0>
> > wrote:
>> i have already seen the jxlib page, but that is not working with me. Do jx
>> work only with fusion 2.0? I have fusion 1.1 and i have problems upgrading
>> to fusion 2.0, cuz the map dont shows
>> On Tue, Sep 14, 2010 at 9:04 AM, zspitzer [via OSGeo.org] <
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5530313&i=1><[hidden
>> email] <http://user/SendEmail.jtp?type=node&node=5530313&i=2>>
>> > wrote:
>> > http://www.google.com/search?q=jxlib
>> > On Tue, Sep 14, 2010 at 4:57 PM, Edi.Karadumi <[hidden email]<
>> http://user/SendEmail.jtp?type=node&node=5529149&i=0>>
>> > wrote:
>> > > where can we find documentations on how to use jx library with fusion?
>> I
>> > am
>> > > using fusion 1.1 and i find a bit difficult to use jx components when
>> > > creating custom widgets.
>> > > View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529138.html<http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529138.html?by-user=t>
>> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529138.html?by-user=t<http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529138.html?by-user=t&by-user=t>
>> > > Sent from the Fusion Developers mailing list archive at Nabble.com.
>> > > _______________________________________________
>> > > fusion-dev mailing list
>> > > [hidden email] <http://user/SendEmail.jtp?type=node&node=5529149&i=1>
>> > > http://lists.osgeo.org/mailman/listinfo/fusion-dev
>> > Zac Spitzer
>> > Solution Architect / Director
>> > Ennoble Consultancy Australia
>> > http://www.ennoble.com.au <http://www.ennoble.com.au?by-user=t> <
>> http://www.ennoble.com.au?by-user=t<http://www.ennoble.com.au?by-user=t&by-user=t>
>> > http://zacster.blogspot.com <http://zacster.blogspot.com?by-user=t> <
>> http://zacster.blogspot.com?by-user=t<http://zacster.blogspot.com?by-user=t&by-user=t>
>> > +61 405 847 168
>> > [hidden email] <http://user/SendEmail.jtp?type=node&node=5529149&i=2>
>> > View message @
>> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529149.html<http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529149.html?by-user=t>
>> > To unsubscribe from Jx API Update, click here<
>> http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=2062075&code=ZWRpa2FyYWR1bWlAZ21haWwuY29tfDIwNjIwNzV8LTE4NTQwODgxMTM=<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=2062075&code=ZWRpa2FyYWR1bWlAZ21haWwuY29tfDIwNjIwNzV8LTE4NTQwODgxMTM=&by-user=t>
>> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529167.html<http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529167.html?by-user=t>
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5530313&i=3>
> Paul Deschamps
> Applications Specialist
> DM Solutions Group Inc.
> Office: (613) 565-5056 x28
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5530313&i=4>
> http://www.dmsolutions.ca <http://www.dmsolutions.ca?by-user=t>
> http://research.dmsolutions.ca<http://research.dmsolutions.ca?by-user=t>
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5530313&i=5>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5530313.html
> To unsubscribe from Jx API Update, click here<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=2062075&code=ZWRpa2FyYWR1bWlAZ21haWwuY29tfDIwNjIwNzV8LTE4NTQwODgxMTM=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5534199.html
More information about the fusion-dev
