[fusion-dev] [mapguide-internals] MapGuide RFC 125 is ready for reveiw
Ted Yang ted.yang at autodesk.com
Thu Aug 16 01:10:12 PDT 2012
Hi Zac,
Thanks for the question. I tried to create RFC on Fusion's Site. While I found I don't have the permission. And there are only 2 RFCs since 2008, and both are "pending" so it looks like there is nobody watching the RFC page at all.
So I just created the RFC under MapGuide trac. The widget will be implemented following Fusion's standard and tested against MapGuide. So in theory it should support also MapServer, but no test is planned.
Best wishes,
Ted
-----Original Message-----
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, August 14, 2012 12:22 PM
To: MapGuide Internals Mail List; fusion-dev at lists.osgeo.org
Subject: Re: [fusion-dev] [mapguide-internals] MapGuide RFC 125 is ready for reveiw
bit of an aside, but as this is directly fusion related, why is this being done under the mapguide trac?  (I have copied fusion-dev in to this thread)
also, in the context of fusion, is this widget mapguide only, or will it also support mapserver?
On Tue, Aug 14, 2012 at 1:29 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi Ted,
> Does this new widget expose any extension properties? If so, could
> they be described in detail in the RFC?
> - Jackie
> http://osgeo-org.1560.n6.nabble.com/MapGuide-RFC-125-is-ready-for-reve
> iw-tp4995004p4995008.html Sent from the MapGuide Internals mailing
> list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
fusion-dev mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
