[fusion-trac] #89: Search panel: incorrect parameters
javascript calls
Fusion
trac_fusion at osgeo.org
Thu Aug 28 17:52:41 EDT 2008
#89: Search panel: incorrect parameters javascript calls
Reporter: pagameba | Owner: madair at dmsolutions.ca
Type: defect | Status: reopened
Priority: P2 | Milestone: 1.0.7
Component: Widgets | Version: 1.0.6
Severity: Major | Resolution:
Keywords: | External_id:
State: Approved | Browser: All
Os: All |
Changes (by poulet1212):
* status: closed => reopened
* resolution: fixed =>
Comment:
I can confirm what cgountanis sais. In the trunk, the
widgets/Search/Search.templ IS the only fix NOT committed. That's why I
reopened the ticket.
So the last thing to do is:
in: widgets/Search/Search.templ
change this:
function CellClicked(sel)
var map = GetParent().Fusion.getMapByName(mapName);
map.setSelection(sel, false, true);
to this:
map.setSelection(sel, true);
Rémy
Ticket URL: <http://trac.osgeo.org/fusion/ticket/89#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
