[fusion-trac] #71: SelectionPanel: Capability to customize
display results
Fusion
trac_fusion at osgeo.org
Tue Jun 10 14:30:45 EDT 2008
#71: SelectionPanel: Capability to customize display results
Reporter: aboudreault | Owner: aboudreault
Type: enhancement | Status: new
Priority: P2 | Milestone: 1.1
Component: Widgets | Version: 1.0.6
Severity: Major | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Comment (by aboudreault):
Ok, i just commited another version of the !SelectionPanel widget in my
sandbox. I created a renderer that produce tables with all results and
their attributes (see the image i've attached). The pagination is also
supported and tested. If you have some improvements to do , no problem.
I'm wondering if we need to allow the user to choose a layout in the
!ApplicationDefinition (Horizontal of vertical: the default one) or simply
let the user define his renderer function/class like the widget does
actually. If not, we can remove the Horizontal renderer from Fusion and
i'll use it for make a !HowTo.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/71#comment:11>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
