[fusion-trac] #80: (Un-)Checking Group in Legend (Un-)Checks All
Contained Layers
Fusion
trac_fusion at osgeo.org
Mon Jun 16 03:37:24 EDT 2008
#80: (Un-)Checking Group in Legend (Un-)Checks All Contained Layers
Reporter: schneiderei | Owner: madair
Type: enhancement | Status: new
Priority: P2 | Milestone: 1.1
Component: MapServer | Version: 1.0.6
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
When a group layer is checked (or unchecked) in the legend, all map layers
the group contains are checked (or unchecked, respectively). This
behaviour is not what the user expects. If the user, for instance,
unchecks a group, all layer it contains should be hidden from the map. If
the user checks the group again, the layers that were visible before
unchecking -- and only these -- should become visible on the map again.
Checking and unchecking a group should not change the visibility status of
the layers it contains. Instead, the visibility status of the group should
simply override the status of the layers.
I suspect that the problem only occurs when using MapServer. In the
functions showGroup() and hideGroup() in MapServer/MapServer.js, there are
the following lines:
-- in showGroup():
for (var i=0; i<group.layers.length; ++i) {
group.layers[i].show();
-- in hideGroup();
group.layers[i].hide();
I believe that these lines can be deleted.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/80>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
