[fusion-trac] #17: Auto-detect map object type
Fusion trac_fusion at osgeo.org
Fri Mar 7 10:57:32 EST 2008
   Reporter:  jfournier    |       Owner:  madair
       Type:  enhancement  |      Status:  new
   Priority:  P2           |   Milestone:  1.1
  Component:  Core         |     Version:  1.0.2
   Severity:  Major        |    Keywords:
External_id:               |       State:  New
    Browser:  All          |          Os:  All
 With the new !ApplicationDefinition structure, each !WidgetSet corresponds
 to a single map object, which may refer to a Map by id. A Map contains
 Layer tags that each have a type that corresponds to an OpenLayers! type.
 Right now, the Map widget in the !WidgetSet is still one of MGMap or
 MSMap. We'll need to make changes, at some point, to grab the layers from
 the Map and create the right !OpenLayers Layer objects for them. I'd also
 like to consider how we could expose some sort of API to simplify (or make
 possible) adding a new Layer at runtime.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/17>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer, MapGuide OS, and MapGuide Enterprise built primarily in JavaScript.
More information about the fusion-trac mailing list
