[fusion-trac] #36: Task pane oddities.
Fusion
trac_fusion at osgeo.org
Tue Mar 25 03:21:55 EDT 2008
Reporter: jng | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone:
Component: Widgets | Version: 1.0.4
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
I have observed some strange behaviours in the Task Pane widget
* The back/forward buttons do not activate/deactivate correctly when
transitioning between pages (eg. via hyperlinks). Is this intended?
* Switching the maps resets the task pane back to the inital url w/
parameters for the current map (it's MAPNAME) which is good, but the task
pane seems to retain the navigation history __before__ the map change
__including__ the parameters of the __previous__ map. This can introduce a
state where your task pane page has a MAPNAME parameter which does not
refer to the current visible map.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/36>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
