[fusion-trac] #42: config.json should be renamed to config_dist.json
Fusion trac_fusion at osgeo.org
Thu Mar 27 11:55:44 EDT 2008
   Reporter:  wbronsema    |       Owner:  madair
       Type:  enhancement  |      Status:  new
   Priority:  P2           |   Milestone:
  Component:  Core         |     Version:  1.0.4
   Severity:  Trivial      |    Keywords:
External_id:               |       State:  New
    Browser:  All          |          Os:  All
 config.json is always in a modified state because this file is custom
 configured per installation.  I propose to rename it config_dist.json so
 as to not interfere with the update and commit operations.
 The only downside is if something is added then you run the risk of
 missing that in your own personal json.config.
 Thougts?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/42>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
