[fusion-trac] #56: Fusion's implementation of QUERYMAPFEATURES
does not support LAYERATTRIBUTEFILTER
Fusion
trac_fusion at osgeo.org
Wed May 7 03:01:14 EDT 2008
#56: Fusion's implementation of QUERYMAPFEATURES does not support
Reporter: jbirch | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.0.5
Component: MapGuide | Version: 1.0.4
Severity: Major | Resolution:
Keywords: | External_id:
State: Review | Browser: All
Os: All |
Changes (by jbirch):
* state: New => Review
* milestone: => 1.0.5
Comment:
I was able to test this change as working against the 1.0 branch. I was
unable to test against trunk; I kept getting an error about !DomNode not
defined. I'm hoping that this is because of the Prototype refactoring?
Anyway... review would be appreciated.
There's an additional parameter called !FeatureFilter that was added in
RFC15 because !MapGuide's viewer search first does two queries, and
querying against geometry can sometimes mean that the wrong feature is
returned the second time around. I don't know enough about the search
mechanism in Fusion to determin whether the same potential for problems
exits. Any comments?
P.S. I don't understand why the branch patch doesn't work with the syntax
highlighting. Maybe I need to replicate the whole trunk/branches thing
locally?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/56#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
