[fusion-trac] #59: Tiled map ScaleZoom Problems
Fusion
trac_fusion at osgeo.org
Thu May 8 23:32:48 EDT 2008
Reporter: zspitzer | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone:
Component: Widgets | Version:
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Using the mapguide slate template and fusion 1.0.5 I have a tiled map
which doesn't init properly in regards to the scale zoom with FF 2 and
IE7.
Using a tiled Sheboygan sample, the Zoom Scale bar defaults to fully
zoomed in, when it's mostly zoomed out. Try to use the zoom control, it
always 'bounces' back to the top position.
and using the mouse scroll wheel, the map actually pans rather than zoom
when zooming out, but not with the Sheboygan sample.
I can provide a demo url for the zoom pan issue (zac dot spitzer at gmail
dot com)
Ticket URL: <http://trac.osgeo.org/fusion/ticket/59>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
