[fusion-trac] #146: Select radius causes map to pan
Fusion
trac_fusion at osgeo.org
Tue Nov 4 12:04:26 EST 2008
Reporter: chrisclaydon | Owner: madair
Type: defect | Status: new
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Keywords:
External_id: 1150366 | State: Analysis Requested
Browser: All | Os: All
Using the Slate template, zoom in on the map once and then invoke the
"Select Radius" command.
When you drag the mouse to define the radius, the whole map pans.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/146>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
