[fusion-trac] #157: Themed layer cannot be switched on/off.
Legend gets multiple redundant layers.
Fusion
trac_fusion at osgeo.org
Thu Nov 6 14:11:50 EST 2008
#157: Themed layer cannot be switched on/off. Legend gets multiple redundant
layers.
Reporter: chrisclaydon | Owner: pagameba
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1154041
State: Analysing | Browser: All
Os: All |
Comment (by pagameba):
The basic problem is that Jx changed a property name (parent to owner)
because MooTools uses parent for something else in its inheritance model.
Changing this in the Fusion code fixes the issue reported, but I've noted
a couple of other legend related problems:
* right click on an item causes an error
* the right-click menu on folders (at least expand/collapse) doesn't work
correctly.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/157#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
