[fusion-trac] #143: Incorrect scale displayed for maps using units other than meters
Fusion trac_fusion at osgeo.org
Fri Nov 7 11:14:33 EST 2008
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  assigned
 Priority:  P1                  |     Milestone:  2.0
Component:  Widgets             |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1085634
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Comment (by madair):
 I got the test package loaded and I think Fusion/MapGuide are behaving
 correctly here.
 All 3 layers (meters/kilometers/millimeters) are using the same underlying
 .sdf data file, however the coord sys overrides in the data source are
 telling MapGuide to interpret the x,y values in that file as meters/km/mm.
 And given that they all have the same extents, the resulting map images
 will be scaled +/- a factor of 1000.  To have the resulting maps appear
 the same the max extents of the layers would have to be scaled by +/- 1000
 to get the same set of resolutions.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/143#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
