[fusion-trac] #168: Legend shows layers that are not initially
visible as checked.
Fusion
trac_fusion at osgeo.org
Wed Nov 12 13:38:27 EST 2008
#168: Legend shows layers that are not initially visible as checked.
Reporter: chrisclaydon | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.0.6
Severity: Major | Keywords:
External_id: 1063451 | State: New
Browser: All | Os: All
In !MapGuide it is possible to specify, in a map definition, whether a
layer is initially displayed in the map. In MG Studio, for example, this
is configured using the "Layer is initially displayed in the map" checkbox
in the map editor.
When the map is loaded in a Fusion application, the legend displays the
layer as checked. A layer that is not initially visible will still not be
rendered initially, but the checkbox is misleading, and must be un-checked
and re-checked in order to get the layer to show up.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/168>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
