[fusion-trac] #117: Widget Architecture change
Fusion
trac_fusion at osgeo.org
Thu Sep 4 10:42:29 EDT 2008
Reporter: pagameba | Owner: madair
Type: task | Status: new
Priority: P1 | Milestone: 1.2
Component: Widgets | Version: 1.0.6
Severity: Blocker | Keywords:
External_id: | State: New
Browser: All | Os: All
The current architecture of how widgets are represented, activated and
deactivated is convoluted, difficult to work with, and inefficient in some
cases.
In the current code, widgets can be either exclusive on the map (put the
map into some *mode*) or not. Widgets that are exclusive are registered
as such with the map object and the map handles deactivating the current
widget when a new widget is activated (that is exclusive).
The Zoom widget is a sub-class of Fusion.Tool.ButtonBase which allows the
widget to represent itself as a button. This is fine for the normal case
of putting the widget in a toolbar. However, the widget can also appear
in a menu (think context menu on the map). In the menu case, we end up
creating a Zoom widget that has a button object that is never used and
manually create a MenuItem for the widget that bypasses the button. The
coding for this is tricky and we end up with a lot of unnecessary object
creation.
I am going to modify the internal architecture of existing widgets and the
base classes to create a cleaner interface for this. At the core of the
change will be the addition of some new members to the Widget class:
* uiClass - this is expected to be either null (the default for widgets
that aren't represented by a button or menu) or a Jx class (either
Jx.Button or Jx.Menu). This will replace both Fusion.Tool.ButtonBase and
Fusion.Tool.MenuBase classes and the inheritance/initialization in the
actual widgets.
* activate - an empty function to be overridden by subclasses that is
called by the uiClass object in the case of a widget being a button or
menu item. This combines what would have previously been the activate and
execute methods in some Widget sub-classes into a single method. Widgets
that were not mutually exclusive had an execute method that is now renamed
to activate.
* deactivate - an empty function to be overridden by subclasses that is
triggered on a mutually exclusive button when another mutually exclusive
widget is activated. This is then used by widgets that establish some set
of event handlers to do clean up when deactivated.
* uiObj - the user interface object that represents this object
* setUiObject - a method that assigns a user interface object (button,
menu item or DOM element) to a the widget. This should be overridden by
subclasses that want to do something to the ui object (such as place menu
items in the menu that was created for them). Previously this would have
happened in the widget's initialize method but the ui object is now not
available until *after* the widget has been created.
This will require changes to all existing widgets that inherit from
ButtonBase or MenuBase and some other widgets. In addition, the
responsibility for creating a user interface object for a widget is now
moved from the widgets to the ApplicationDefinition.js code where the
widgets are initially created.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/117>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
