[fusion-trac] #100: Allow specifying destination filename for
single file build
Fusion
trac_fusion at osgeo.org
Fri Sep 5 10:04:40 EDT 2008
#100: Allow specifying destination filename for single file build
Reporter: jbirch | Owner: madair
Type: enhancement | Status: assigned
Priority: P2 | Milestone: 1.1
Component: Core | Version: SVN
Severity: Minor | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by madair):
* status: new => assigned
* version: 1.0.6 => SVN
Comment:
some other improvements:
- make setting the AppDef property optional so that any AppDef can be
loaded at runtime
- add a target to concatenate and compress CSS files
Note that care must be used with a concatenated and compressed CSS file
because url() elements in the CSS file are relative to the CSS file
itself, not to the application.
Using singleFile pacakges requires updates to your templates to point to
the relevant packages
Ticket URL: <http://trac.osgeo.org/fusion/ticket/100#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
