[fusion-trac] #121: Regression: Selection in an MGE Flexible Web
Layout fails if a raster layer is visible and selectable
Fusion
trac_fusion at osgeo.org
Wed Sep 10 15:18:05 EDT 2008
#121: Regression: Selection in an MGE Flexible Web Layout fails if a raster layer
Reporter: davewilson | Owner: madair
Type: defect | Status: new
Priority: P1 | Milestone: 1.1
Component: MapGuide | Version: 1.0.7
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: Windows
Create an MGE map with 2 or 3 layers where one of them is a Raster image.
In the map definition by default a layer is marked as selectable. If the
user switches to select mode and drags a rectangle so select some features
while the raster layer is visible the layout will hang for a minute or so
and eventually an AJAX Callback error with a server exception is raised
saying "Error: Cannot create any more connections to the Autodesk.Raster
FDO provider". This was not an issue with the version included in the 32.2
RTM build of MGE 2009.
A workaround is possible by setting the raster layer to not be selectable
in the map.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/121>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
