[fusion-trac] #116: Legend.js: startGroup Initial value is
checked, wether or not set in Studio
Fusion
trac_fusion at osgeo.org
Fri Sep 12 13:19:59 EDT 2008
#116: Legend.js: startGroup Initial value is checked, wether or not set in Studio
Reporter: poulet1212 | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.1
Component: Widgets | Version: 1.0.6
Severity: Major | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Comment (by jbirch):
I'm not able to duplicate this problem using the 1.1 branch. When I
change the value of whether to show the group initially in either Maestro
or MG Studio, Fusion seems to honour this change.
As far as I can tell, the code change that you suggest only affects the
top-most group, which is the name of the Map (e.g. Sheboygan). The other
map groups are toggled in the processMapGroup method based on the value of
the group's visibility.
I think that the Fusion developers will need additional information to
track down the problem you are seeing, such as MapGuide version, the
version of Fusion that you're using, and a package (MGP) that shows the
problem.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/116#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
