[fusion-trac] #65: mgmapresourceid URL override patch
Fusion
trac_fusion at osgeo.org
Tue Sep 16 14:58:32 EDT 2008
Reporter: amorsell | Owner: madair
Type: enhancement | Status: closed
Priority: P3 | Milestone: 1.1
Component: MapGuide | Version: 1.0.6
Severity: Trivial | Resolution: fixed
Keywords: | External_id:
State: Committed | Browser: All
Os: All |
Changes (by pagameba):
* status: new => closed
* state: New => Committed
* resolution: => fixed
Comment:
I was about to suggest the same approach as Mike, which is to pick up the
resource id from the URL in the MapGuide initialization using the
Fusion.getQueryParam() function.
As Mike indicated, this is now supported but you would construct the url
as follows:
http://yourserver:8008/mapguide/fusion/templates/mapguide/slate/index.html?theme=Library://Samples/Sheboygan/Maps/Sheboygan_2.MapDefinition
Ticket URL: <http://trac.osgeo.org/fusion/ticket/65#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
