[fusion-trac] #126: Double Map Name in Custom Tasks
Fusion
trac_fusion at osgeo.org
Tue Sep 16 16:01:57 EDT 2008
Reporter: cgountanis | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.1
Component: MapGuide | Version: 1.0.7
Severity: Major | Resolution:
Keywords: | External_id:
State: Approved | Browser: All
Os: All |
Changes (by pagameba):
* state: Analysis Requested => Approved
Comment:
Actually, I spoke too soon - I was looking in Studio for something else
and realized that there are two widgets in play here, TaskPane and
InvokeURL, and it turns out that both of them are adding the three
parameters to the URL. I'm not sure which widget's implementation is
better, but "there can only be one"!
Thinking this through a little, InvokeURL can open a page in either the
task pane or another frame or a separate window, so it needs to add the
parameters. Other widgets like BufferPanel can do the same. I think that
the extra parameters should be removed from the code in TaskPane.
Mike, please review this and see if there are any other widgets that can
target the taskpane that don't add the parameters and adjust them to add
the parameters, then remove that code from TaskPane.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/126#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
