[fusion-trac] #113: Can't zoom out beyond initial map view
Fusion
trac_fusion at osgeo.org
Tue Sep 16 22:20:16 EDT 2008
Reporter: andrewd | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.1
Component: Core | Version: SVN
Severity: Critical | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by andrewd):
* milestone: 2.0 => 1.1
Comment:
You're over complicating things. No one's asking to be able to set any max
extents - Fusion seems to be doing that all too well on it's own, hence
the problem. Fusion should allow you to zoom out as far as you like, if
your layers are set to go to infinite, which is the behavior in AJAX and
DWF viewers. Period. Make a map...view it in an AJAX layout...zoom out.
Note that it works. Now make a Fusion layout. Zoom out. Note that you
can't. There's the bug. Right now, Fusion v1.1 is totally undeployable for
me. Since it works for the other viewers, why should it be such a hard
fix? It seems to me like it's likely just someone setting a hard max limit
on something, where they shouldn't be.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/113#comment:12>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
