[fusion-trac] #113: Can't zoom out beyond initial map view
Fusion
trac_fusion at osgeo.org
Thu Sep 25 16:02:55 EDT 2008
Reporter: andrewd | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 1.1
Component: Core | Version: SVN
Severity: Critical | Resolution: wontfix
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by madair):
* status: new => closed
* resolution: => wontfix
Comment:
this is an artifact of the OpenLayers library. The DWF and AJAX viewers
don't use OpenLayers as the mapping engine.
In theory you can do this by simply not specifying a maxExtent for the
layer (or map) but you then end up with the default maxExtent of
-180,-90,180,90 and maps in EPSG:4326 can zoom out to that, but it is
definitely wrong for maps in other projections.
IMHO there are problems with the way that the map extent handling has been
implemented in OpenLayers, and I suspect mostly due to OL origins as a map
tiling client, but that is the behaviour that OpenLayers provides.
If you can provide an example of OpenLayers that allows zooming out beyond
the maxExtent, please re-open this ticket with a link.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/113#comment:13>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
