[fusion-trac] #113: Can't zoom out beyond initial map view
Fusion
trac_fusion at osgeo.org
Thu Sep 25 20:05:25 EDT 2008
Reporter: andrewd | Owner: madair
Type: defect | Status: reopened
Priority: P2 | Milestone: 2.0
Component: Core | Version: SVN
Severity: Critical | Resolution:
Keywords: | External_id:
State: Analysing | Browser: All
Os: All |
Changes (by pagameba):
* status: closed => reopened
* state: New => Analysing
* resolution: wontfix =>
* milestone: 1.1 => 2.0
Comment:
Mike, it wasn't my intention that we would not address this issue (sorry
for the double negative there). I think Andrew's use case is as valid as
ours, it just doesn't fit in the current architecture/limitations of our
implementation. I do think that we need to look at this again for the 2.0
version and see if there isn't another way to work around the OpenLayers
max extent issues while still preserving a mechanism to have a max extent
for our needs.
Andrew, thanks for sticking with it this far, unfortunately, we can't
address this in the scope of the 1.1 version.
I understand that you are frustrated with the limitations and bugs in
Fusion and hopefully the next release will be more satisfactory to your
needs and you will give us the benefit of your involvement again at that
time.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/113#comment:15>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
