[fusion-trac] #344: Object drawn by Redline with consumer map
	didn't display until Zoom map.
    Fusion
    trac_fusion at osgeo.org
    Thu Dec  3 22:20:30 EST 2009
#344: Object drawn by Redline with consumer map didn't display until Zoom map.
 Reporter:  liuar    |         Owner:  madair
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  Future
Component:  Widgets  |       Version:  1.1.1
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:  1281964
    State:  New      |       Browser:  All
       Os:  All      |
Comment (by liuar):
 Updated the resoution per Paul's suggestion.
 Added a function named moveLayerToTop for moving the redline layer to the
 top and redrawing it after feature added in this layer.
 [[BR]]
     featureAdded: function(evt) {
         this.triggerEvent(Fusion.Event.REDLINE_FEATURE_ADDED,
 evt.feature);
                 this.moveLayerToTop(evt.feature.layer);
     // move the redline layer to the top and redraw it
     moveLayerToTop: function(layer) {
         var map = layer.map;
         var baseIndex = map.getLayerIndex(layer);
         if(baseIndex != layer.map.layers.length-2)
             // except for the current temp drawing layer, the redline
 layer is not on the top of the map.
             map.setLayerIndex(layer,layer.map.layers.length-2)
         layer.redraw();
Ticket URL: <http://trac.osgeo.org/fusion/ticket/344#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
