[fusion-trac] #350: External Providers widget doesn't work
Fusion trac_fusion at osgeo.org
Fri Dec 11 02:56:51 EST 2009
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1288337  |       State:  New
    Browser:  All      |          Os:  All
 Report from Autodesk QA.
 Steps:
 1. Open one flexible web layout with consume maps.
 2. Click External Providers widget.
 Results:
 Nothing happened.
 Expected results:
 The drop-down menu should display with all selected base layers.
 Workaround:
 Per information from Arthur, click Map widget first, then it works.
 Regression: Y
 G29.8 works correctly.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/350>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
