[fusion-trac] #304: unknown error when zoom with disconnected
server connection
Fusion
trac_fusion at osgeo.org
Fri Dec 11 03:29:24 EST 2009
#304: unknown error when zoom with disconnected server connection
Reporter: christinebao | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: Future
Component: Core | Version: 1.1.1
Severity: Major | Resolution:
Keywords: Failover | External_id: 1250151
State: New | Browser: All
Os: All |
Comment (by christinebao):
== Tech diagnosis: ==
Typically an error is handled in this way:
1. If an exception occurs in MapGuide server, the server will throw out
exception, and web tier will translate it into an HTML page, for example:
[[BR]]
<html>
<head>
<title>MgDbException</title>
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
</head>
<body>
<h2>An exception occurred in DB component.</h2>
</body>
</html>
[[BR]]
2. Fusion get the response, and put the HTML content into its error
handler.[[BR]]
xml2json: function(callback, r, json) {
if (json) {
var o;
eval("o="+r.responseText);
callback(o);
} else {
if (r.status >= 400) {
Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
'xml2json: invalid XML document: ' +
r.transport.responseText + " : " + r.request.url));
return;
[[BR]]
3. MapGuide template deals with the error handling string, get the
readable message by parsing <h2></h2>. [[BR]]
var fusionError = function(eventId, error) {
var errorMessage = error.toString();
var readableMessage = '';
//Case 1: For dealing with Function: convertXML (fusion.js)
// xml2json: function(callback, r, json) {
// if (json) {
// var o;
// eval("o="+r.responseText);
// callback(o);
// } else {
// if (r.status >= 400) {
// Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
// 'xml2json: invalid XML document: ' +
// return;
var tagStart = '<h2>';
var tagEnd = '</h2>';
var indexStart = errorMessage.indexOf(tagStart);
var indexEnd = errorMessage.indexOf(tagEnd, tagStart);
if (indexStart != -1 && indexEnd != -1) {
readableMessage = errorMessage.substring(indexStart +
tagStart.length, indexEnd);
readableMessage = readableMessage.replace(/\\n/g, '\n');
readableMessage = readableMessage.replace(/\\t/g, '\t');
Then a user-friendly error message pops up.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/304#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
