[fusion-trac] #79: Allowing for Nested Groups in Legend when
Using MapServer
Fusion
trac_fusion at osgeo.org
Thu Feb 5 09:19:35 EST 2009
#79: Allowing for Nested Groups in Legend when Using MapServer
Reporter: schneiderei | Owner: pdeschamps
Type: enhancement | Status: closed
Priority: P2 | Milestone: 2.0
Component: MapServer | Version: 1.0.6
Severity: Minor | Resolution: fixed
Keywords: | External_id:
State: Analysis Requested | Browser: All
Os: All |
Changes (by pdeschamps):
* status: new => closed
* resolution: => fixed
Comment:
added login in the scale processing to reset the layers min / max
scales to be set to the main map's min man scales if they happen
to exceede the main map scales. without this you get un expected
ui behaviour in the legend.
/fusion/trunk/layers/MapServer/php/LoadMap.php REV # 1776
I added closes comment in the commit however it did not close the bug
Ticket URL: <http://trac.osgeo.org/fusion/ticket/79#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
